New member Username: Demented_davePost Number: 1 Registered: 02-2004 | i have the 51s500 model and i think mine might have a problem as the images look static kind of like whwn you watch a movie on a computer pixelated also if you get real close to it you can see well a rainbow like when you shine light thru a prism its about 5 inches square in the middle of the screen then 8 inches long rectangle at the bottom, the images is extremely grainy close up, any of those things going on with anybody elese Dave dchristiansen3@cox.net |
Shawn Unregistered guest | You are viewing the TV too close. Big screen TV's look best from a distance, that way you do not see the pixelation. How far back are you viewing the TV from when you see this problem? |
New member Username: Demented_davePost Number: 2 Registered: 02-2004 | I can see it from 10 feet away (my viewing distance)and it is also very graining the wierd thing is if i look at the tv from an angle(left rigth up or down) it looks fine |
