big o Unregistered guest | I just got a Kicker L7 "12 and on one of the recommended vented boxes it says: Fb=37Hz. I'm rookie and was hoping someone could help me out. |
Help2 Unregistered guest | Its the tuning frequency of the box they recommended. If you follow the plans, thats what the port will be tuned to, meaning that will be the center frequency the sub will play at. |
big o Unregistered guest | so should i set my bass boost at 37Hz? |
Silver Member Username: CarguyPost Number: 543 Registered: Nov-04 | No guy, if you build the box according to the spec, the box port will give you 37Hz. |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 6017 Registered: Dec-03 | a ported box has a tuned frequency. this is where the box is most efficient and puts out the most bass with the least power essentially. the tuned frequency is based on enclosure volume, and port cross-sectional area. If you want a pre-made box for an L7 try www.bigdogcaraudio.com they carry several I believe. all built to spec for those subs |
