I am new to home theater speaker system. I am very interested in Pinnacle Quantum and Polk RM7600. If anyone can give me any information to compare these two systems. I'm also thinking about the receiver eather Denon AVR-3803 or new AVR-3805. I will appreciate it and thanks in advance!
I really can't give you any advise on the Polks but I just bought the Pinnacle Quantums and they are awesome for their size. The sub is just an 8" box but really puts out some strong, smooth base.
Vova, Do not buy a Denon if you plan on using eitherPinnacles or Polks. Both are a bit on the bright side and need a mellower receiver. I had a Denon 3803 and it's brightness, sibilance and thinness were unbearable. For the price of the speakers you are looking at your money would be better spent on a cheaper receiver that better matches the speakers and I would recommend you check out the Marantz 5400. Lots of power and a perfect sonic match. Good luck.
Thanks for pointing me into Marantz. I heard a lot about them, but never had a chance to listen to them. What about new SR7500? Will it fit eather Pinnacle Quantum or new Polk RM6900, or Polk RM7300? Thanks.
