I locked out some channels and now I forgot the password, is there any way of getting around this.
Yildchild 69
do a dump and it will set it back to default. menu,6,3,info,browse,theme, then a dump screen should appear if not cancel out to the start and try over, if yes press tv/video button, then unplug the receiver's power cord from the wall. Plug back in after about 5 sec and it will aquire sattellite signal and you should be fine.
