Connecting amplified speakers to dvd/vcr player
Username: Dkeller
Sacramento, CA United States
I have Provision speakers with an amplified subwoofer (no receiver required) and want to connect them to our Samsung dvd/vcr player that is dts ready. The dvd player has only a coaxial output but the speaker system has 6 plugs to go into a dvd player. Is there some kind of converter? Or is the speaker system designed for only a specific type of dvd player??
Username: Project6
Post Number: 1914
Do the speaker system have any digital inputs?
Have you checked the manual?
Username: Dkeller
Berny - Thanks for the response. The speakers do not have an digital inputs and the manual is not very helpful. They do not have a website either. I checked at store today with another similar system, same issue. Maybe it's my dvd player? It only has the coaxial output.
Username: Project6
Post Number: 1920
Sorry to say, but you have been misled. The subwoofer may not need a receiver but the rest of the speakers will need to have receiver to be driven. the DVD player need to be connected to a receiver that can decode digital signals.
You need a receiver.
