JL Audio XR653CS Kick Panels
Username: Jinsus
Post Number: 7
I was wondering where I could get some quality kick panels for the JL Audio XR653CS.. I'd be putting them into a 99 monte carlo. Thanks.
Username: Jonathan_f
GA USA
Post Number: 2649
Really, the Q logics will work pretty well with a 3 way system since you have a midrange that doesn't have to produce midbass. Just stuff it with polyfill and put some sound deadening on it. Then, you could use a door location for the 6.5" midbass.
