JBL E150P -- any good?
Username: Destro713
Chicago, IL U.S.A.
Post Number: 14
http://www.jbl.com/home/products/product_detail.asp?ProdId=E150P&SerId=NRE&sCatI d=PSU
Well?
Freakshow
Save your money.
Buy SVS.
<shameless>
edster922
Just bought one of these, it's not bad at all, just need to play around with placement and settings.
Got mine off eBay for $178 shipped, brand new.
Username: Destro713
Chicago, IL U.S.A.
Post Number: 15
From what I can tell from reading the SVS website, their cheapest possible subwoofer exceeds my budget by well over 100%.
Anybody else used the E150P or other JBL subs?
edster922
looking back I'd probably get the E250. New, it's just another $50-70 on eBay for the extra 2" on the woofer and an extra 100 wpc. My listening room is pretty big with cathedral ceilngs, so I could use the extra power.
My Onkyo receiver arrives on Thursday and it has adjustble crossovers so I'll send all the low frequency signals exclusively to the sub...THEN I'll be able to figure out just how good it really sounds.
