If money is not a problem for you, Rockford and Kicker make amps powerful enough to drive them. If possible look for amps with remote bass control. Me personally I'm using Audiobahn A4125HCT (2000W rms) and it pounds. Someone else on here posted about 2300HCT (1600W rms) model.
for my 2 audiobahn aw1208t's, i think im going to put 2 amps in my car. Would you recoment the rockford T30001, the kicker KX2500.1, or the audiobahn 2300HCT. If none of the above which amps would you recommend and please be specific. thanks again
Hey if money is not a problem with you, I'd go with Rockford T30001, then KX2500.1, and if money is a concern, then 2300HCT. From what I've seen Rockford is 1 ohms stable wherelse Kicker is only 2 ohms stable. You get 3000W rms at 1 ohms with Rockford. My 3rd choice is 2300HCT cause it puts out at a low price and it's been tested. I hope you have an alternator that can handle that much power.
I think im going to go with the Rockford T30001, but my question is how many do you recommend 1 or 2? either way im puting another higher output alternator in. thanks again
