New member Username: RetiredjetpPost Number: 2 Registered: Dec-04 | Does it make any difference whether I buy a $10 Radio Shack cable tv signal booster or a Motorola I saw at Circuit City for $49. In other words do they all provide the same result. Chuck |
xvxvxvx Unregistered guest | For what purpose? If it to boost your cable signal you had better be sure it is a two-way amp otherwise you will lose much functionality from your cable box. Post a link to each one and I'll be happy to tell you if either will work as well as another. xvxvxvx |
New member Username: RetiredjetpPost Number: 3 Registered: Dec-04 | http://www.audio-discounters.com/m61111.html |
xvxvxvx Unregistered guest | The CC amp will certainly work. The Motorola unit M61111 you linked to does have the necessary bandwidth however I searched carefully and cannot verify that it will indeed pass two way communication which is a must if hooked to your cable line. xvxvxvx |
New member Username: RetiredjetpPost Number: 4 Registered: Dec-04 | >>cannot verify that it will indeed pass two way communication which is a must if hooked to your cable line.<< Why do I need two way comm. for cable tv? Chuck |
