I have a 1600 watt peak amplifier with 4 channels 2 channels indicated as front speakers and 2 channels as rear. how would i bridge the four of them together to make 2 channels at 4ohms
Hey Robert, normally in 4 channel amp, channels 1 and 2 gets bridged to 3 and 4. You should check your manual. It should also be labeled on the speaker terminals or at the bottom of the amp case.
yeah please check the amp manual usually there is a switch or button to enable bridged mode. then you use a specified pair of wires from the bridged channels to run the speakers.
