ok i need some help i was told these where good subs Alpine SWR-1541D 15" Dual 4-ohm Voice Coil Component Subwoofer i have no idea but there cheap and run about $190 a piece. I was goin to get 2 so now all i need to know is, are these good speakers? what amp do i need? do i need anything else?
If you are getting two then you will need a 1 ohm stable amp or you could get 2 ohm dual voice coils and get a 2 ohm stable amp. If you are getting one 4 ohm dvc then you will need a two ohm stable amp. Don't forget the amp wiring kit.
