Car Audio Has Cut Out
DoItForTheKids
Car Audio has come to a cease in the last few days, actually over the last 3 months, but it has worked off and on, and the audio would play if i messed with my power mirror settings a little bit, but now that will not work. Would work during accelerations for a bit also.
Anyone have any ideas?
DoItForTheKids
need some kind of advice plz :-(
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5754
take it to a shop and let an installer look at it.
it sounds like a wiring issue.
