Kenwood Amp Problems
Username: C12698
Oklahoma
I have a kenwood kac-929 and it worked great for awhile. Then all the sudden it quit sending power to the subs and the power light on the amp comes on for a second or two then it will go off and on like it was shorting out. All wires and everything is hooked up correctly. Is there something wrong inside the amp that I need to get fixed or whats the deal???????
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5742
sounds like the amplifier failed. internal short somewhere.
yeah it needs to be repaired or replaced
