RE MT!!!
What is the RMS and peak on these subs i couldnt find it on there site anywhere.
Help2
They dont give them.
Theyre strictly SPL subs.
so...RMS is probably more than
you can give it.
so one 10" would be a good sub to go with if i want spl or does the x.x.x. have anywhere near the same amount of spl?
kylerensmeyer
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18804%26item%3D5732100279 %26%26
what do you guys think of that??
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5783
the triple X subs are damned loud. if you want incredibly loud subs with good SQ, get those.
the MT is strictly meant for SPL event competitors, and not a daily driver sub.
The HC15 is a great sub.. it's got 21mm Xmax versus the triple X's 32mm, so it's not going to be as loud, but it's still a great sub.
