Infinity Sub Problem
Username: Raydawgvt
I'm having a problem with an Infinity Kappa Perfect 12 I bought from a friend of mine. I hooked it up and it worked fine for a while, then just stopped working. Now the only time it works is if I press a little on the suspension, after which it works for a few seconds then stops. Any ideas what is going on? I'm desperate here, because the hour or so it worked, it sounded awesome.
Username: Bnh142
Post Number: 12
I have never heard of that problem before but I'm no expert. Does it go compleatly quiet when it stops? This sounds like there may be a loose electrical connection somewhere.
Help2
Could be loose/broken tinsel leads.
Not much you can do if thats the case.
