Loud treble
Username: Ctx
Post Number: 91
I was wondering what amp/speakers I should use to get the loudest treble possible for under 150$
Username: Blownriv
OH USA
Post Number: 37
pioneer 5-way 6x9s might do the trick.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5592
Infinity Kappa 6.5" separates are known for having very bright tweeters. Pretty much anything using a metal film or neodimium tweeter will be very bright.
avoid cloth or silk dome type tweeters. they tend to be very flat and smooth. softer and not as bright as metal types.
notaniceguy
logon onto www.etronics.com and get
1 PowerAcoustik OV2-400 Gothic Series 2-Channel Amplifier $59.99
6 Pyramid TW27 High PerformanceTri-Mount Tweeter in Clam Shell Packaging (Pair) $9.99
hook the tweets up on your rear deck <or> in a series/parallel configuration and connect to your amp and you should be good to go.
good luck and enjoy
Username: Glasswolf
Post Number: 5608
hahahhahaa
Username: Romesaz
Ontario Canada
Post Number: 12
hm...I dont know whats more amusing. The fact that Glass just laughed at the guy, or that there are speakers for 10bucks for the pair...lol
Username: Glasswolf
Post Number: 5632
well, he mentioned power acoustik and pyramid, and in the same breath.
I figured it had to be a joke..
