Hi, I have a four channel amp that feeds front and rear speakers. What is the best way to reduce the output to the rear speakers. I have read that I could use an L-pad to passively reduce the output and have some control. Are there any other methods that I am not aware of?
The fader will not work since I have the four speakers connected to the single amp. I used the other low level output to another amp which drives the subwoofer. Therefore, the fader will only switch between the four speakers and the sub. I need a way to reduce the output on the rear deck speakers to balance the staging.
