well to tell you the truth you can use a linkys or d-link wireless 802.11b adapters because there are alot of ISP that you won't need to use the wireless g technology on the XBOX most ISP's provide you with no more than 1.5Mbps so its is easy to buy a compatible adapter for 60 or 70 bucks.. I hope this helped
