i know alot of people ask this question but what materal should i get to build a sub box ............2 12's and a ten all in the same box ...........all materials pleeze ....thanks alot
Either 5/8" or 3/4" MDF, wood screws, Liquid Nails, silicone sealant, spray adhesive and box carpet. A table saw or a circular saw and jigsaw would be a big help.
LM
Help
You dont want to put 2 12" and a 10" in the same Car, let alone the same box. Youll get noise cancellation up the wazoo.
