Hooking up subs with 2 ohm voice coils ?
Ok i have 2 kicker 12" l5 subs with dual 2 ohm voice coils and a jbl 1200.1 amp that runs 1200 watts at 2 ohms. How can i hook these up so they are set for 2 ohms? If you wire them parallel then they play at 1 ohm and if you use a series it uses a 4 ohm load. How the hell do you hook this thing up ?
Username: Insearchofbass
Post Number: 935
easy to do go here
http://www.rockfordfosgate.com/rftech/wiringwizard.asp
Damien Rob.
Your going to want to wire the coils together in series then wire the subs together in parallel then to your amp, this will give you a 2 ohm load with two 2 ohm DVC subs.
