New member Username: Doitbig22Frankfort, Ky Us Post Number: 1 Registered: Oct-04 | I HAVE A PROBLEM I JUST BOUGHT A JL 12 W7 AND FIGURE OUT HOW TO GET IT OUT OF THE BOX ITS NOT IN A JL BOX OR ANYTHING ITS JUST A REGULAR WOOD BOX |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 4506 Registered: Dec-03 | on a W7, the surround rolls over the mounting ring. Go to www.jlaudio.com they have a PDF file on that sub that should explain with pictures how to install/remove it. |
Bronze Member Username: Audionoob13Novi, MI USA ... Post Number: 51 Registered: May-04 | theres a snap like Ring that you need to pray off with a flat head screw driver, and theres a huge O-ring that needs to come off. after that squezze the foam/or whatever you want to call it and it will reveal the screws! |
