Doug Unregistered guest | I have 2 Alpine type S. They are dual 4 ohm. I saw that there was a way to wire 1 sub to 2ohm for a 1 channel amp so If I have a 2 channel amp and 2 subs wired down to 2 ohms going into each channel would that be presenting a 2ohm load to the amp or is it a 4ohm load? |
Silver Member Username: InsearchofbassPost Number: 834 Registered: Jun-04 | it would be 2 ohms each channel in stereo |
Silver Member Username: InsearchofbassPost Number: 835 Registered: Jun-04 | 1 ohm or 4 ohm in mono with the two 4 ohm dvc's in case you need to know that |
Doug Unregistered guest | so If my amp puts out 300x2 RMS at 2ohm would it be putting out the full 300 watts? |
Silver Member Username: InsearchofbassPost Number: 837 Registered: Jun-04 | yes but then you will need a coil to cross over the subwoofers at the right frequency so you dont damage the subs |
Silver Member Username: InsearchofbassPost Number: 838 Registered: Jun-04 | thats if your running them in stereo |
New member Username: Marck05Halifax, NS Canada Post Number: 5 Registered: Oct-04 | http://www.rockfordfosgate.com/rftech/wiringwizard.asp try this for your troubles |
