How much power does jl 500/1 put out?
Bass_Daddy
I recently got the jl audio 500/1 amp and i got 2 audiobahn aw1571t's and it sounds great right now but i have them running at 1 ohm and the subs can handle 500 rms each so if i turned the amp up all the way, does anyone think i will blow my subs?
misterHT
Try it, see how much it can take.
AaronMoDick76
audiobahn sucks...i bought a single aw1571t last week, running it at 2 ohms off a concept ca525m mono amp, with the amp not even up halfway. sounded good for a few days, then the voice coils fried. they are cheap pieces of sh*t.
