I need help on a combination of woofers amp and my cd player
Username: Cris
I have 2 soundstream spl 15"(800w) each and a jvc cd player with an orion 2150 sx(300w rms) i was wondering if that is a good combination or should i get something else to make it pound
Username: Project6
Post Number: 1581
try posting under the Car Audio forums. You'll get excellent help there:-)
mikerdx
If i use two 1000(wt) sony amps to two 1500(wt) subs and to 3 120(wt) sony speakers will the 120(wt) speakers blow. will it just sond ok if the subs are just on the amp and the speakers are on the cd player. pleas and thankyou foer any tips you have.
