Anonymous | Hey guys looking for recomendations of an amp that will be able to safely push about 1000 watts in a one ohm load since that is most likely how I will power my X.X.X I was planning on wiring it on a 1 ohm load unless it's possible to wire a DVC 2ohm sub at a 2 ohm load...if so how is it done? The only amp that isn't insanely expensive that is stable at 1 ohm and rated at 1000 watts is the Hifonics Brutus 1000D amp. Is this amp truely 1 ohm stable and will it truely give me 1000 watts? If it is and does then it should be enough for my X.X.X right? |
Bronze Member Username: SasPost Number: 50 Registered: Sep-04 | 1500@1 ohm so they say i am using it to power 2 kappa perfects at 4ohm and they dont hit hard at all |
Silver Member Username: Zacdavis~Post Number: 120 Registered: Sep-04 | your sub can be wired to 4ohm or 1ohm, and i think you'd be impressed by SPL's Z1X-2400D amp, it puts out 1800rms @ 1ohm. |
Anonymous | Thats way too much power...the rms of the X.X.X is 1600 watts and that's thermal so that's too much. Just wondering if Hifonics overates their amps and if it really is stable in a 1ohm config, Johnathan your opinion is wanted if you can...thanks to anyone who can help though |
