Converting Origninal CD's into MP3 Files
Username: Spirntcarcowboy
Seal Beach, Cal USA
Post Number: 11
What are the best programs to do this? Does it take long for each CD to be converted? Does this effect the sound quality of the music? Anything else tip wise you can fill me in on?
Joe
Username: Kksoo
Milwaukee, WI USA
I use Musicmatch Plus and it does a very good job. I have also used Roxo's version 6 with good results as well. It does not take any longer than ripping a CD. The playback quality in my car is excellent.
Rod V
Here is a link to print the manual for the cdx505rf and other products. http://www.iq.sony.com/srvs/sosdocs/default.asp?src=sonysupport
Username: Ps1k0
Post Number: 18
you can also use windows media player 9 to do it.
well, it'll rip to wav files then you need a .WAV to .MP3 converter.
rknrne
Thanks Rod .... I'm printing all 16 pgs right now
