i have a sealed box here for 2 10 inch subs. I have 2 ports out of another speaker that measure about 3 inches in duameter and about 8 inches deep. Can i put theese ports between the 2 speakers in my sealed box? i have seen several ported boxes about this size with ports located there...could i expect better results or a crappy sound?
if you were tuned to the right frequency yes you would see better bass response but you must port according to the box size and frequency response of your subwoofers
Yeah you could do it just as long as there tuned right for the box. If you find its not, then go to Home Depot and get some PVC pipe, then you can cut it to the right length.
