Need p4 & p5 card reader
Username: Satanluvsme
does anyone know where i can get a card reader?
applebee
isn't one yet..a "card reader" is a combination of hardware and software..and NO confirmed hardware works for the P4/5 yet,EXCEPT using your old HU loader flashed to UL4S and using winexplorer software file P4-D1 card checker UL4S v3.zip...this will ONLY do a PARTIAL read of the card,nothing else works at this point in time...U need to wait until there is a true stable P4/5 hack released to know what hardware and software is really going to be needed..RUMORS are that a simple iso programmer,winexplorer scripts,and BasicH program might be all that are necessary...time will tell.
Username: Bluejames2003
I bought 2 p5 cards on line that are guaranteed to get the preveiw channels..is there something speciasl I must do or did I get scammed.
applebee
any/all P4/5 card will get the preview channels!..but thats all U'll get now,until the P4/5 hack is released and made public..then U'll have to program them..
Finish 24
I can get them programmed them for U ---Just send me $50 bucks /ea.
details here.... finish24@aol.com
Username: Jmill1948
Chester, Va Usa
Post Number: 287
here you go.............
Top View
$22.99
Usually Ships: 24 hours
Product Specifications:
Protocols: T=0, T=1
ISO Rating: ISO-7816 (Parts 1/2/3)
Clock Frequencies: 1.2288MHz / 3.57945MHz / 3.6864MHz / 4.608MHz / 9.216MHz / 18.432MHz
Interfaces: RS-232 DB-9
Power Input: +7.2 to +24VDC @ 200mA
Dimensions: 3.5" x 2.5" x 0.5"
Power/Mode/Data Flow Indications: (6) Multicolored SMT LED's
O/S Supported: Any O/S that supports the RS-232 Standard
Included Accessories:
(1) 6' DB9 Computer Interface Cable
(1) 117VAC/9VDC 300mA Wall Adapter
(4) 3M Insulated Bump-on Rubber Feet (Installed)
Model: SKU 3441
●Shipping: Free Shipping
Compare at: $280.99
Our price: $269.99
Product Details: This loader we assume that soon,will be the Unit to P4-P5 card, We are in Test. If you have any Questions please e-mail us
True universal ISO-7816 - 1/2/3 compatibility
On board hardware based universal smart card reader/writer
Microsoft PC/SC compatible (USCT PC/SC Driver Required) .
On board universal smart card diagnostic and recovery system
On board Atmel AT90S2313-10PI Micro-controller For P4-P5 card Test AT90S8515-10PI.
On board (ICP) Atmel programming interface.
Will gain entry to cards previously untouchable by *old* code
Future Unlock updates for Unlocking future Dealer Lock down 3M scripts One unit, one mode, does it all without any re-flashing.
Provides the solution for cards that won't open with existing loaders and programming.
Repairs otherwise un-glitchable card.
One switch mode selection.
All matched and hand selected device components
No hardware device drivers needed in direct RS-232 mode
Supports all speeds of serial communication up to 115,000 baud
Compatible with all MCU smart cards and most Memory Only cards
Compatible with all RS-232 smart card development software
Supports both commercial and military power specifications
Only true hardware based universal all-in-one S-C terminal available
Amphenol "snap-in" card slot rated at 200K+ insertions
Incorporates the exclusive and convenient SDLOGIC ON/OFF switch
Incorporates a 20-pin dip socket for easy removal of Atmel chip
Incorporates a 4 position switch selector for modifiable timing slopes
Incorporates the proven SDLOGIC INTERSIL RS232 Chip
Incorporates a new heavy duty DC jack
Incorporates a new surface mount heavy duty voltage regulator
Incorporates (5) separate Philips74Hc4053N
Separate mode indicators
Atmel Pin 1 Jumper Enable/Disable /Bridge.
Enhanced high-speed buffer circuitry support (Jumper Enable/Disable)
New anti-static/chemical coating treatment to the Amphenol card slots
BIG SCAM
Username: Jmill1948
Chester, Va Usa
Post Number: 297
you think so?
IM 100% POSITIVE
IM 100% POSITIVE
