You have to use the optical/digital in/out or if you have 6 channel analogue you can get the separation as well. The red/white analogue is for stereo separation or pro logic applications.
No, the video does not go to the optical port. You have to use video inputs on your receiver or TV, via composite, s-video or component.
JonD
Thanks! i appreciate it.
any opinion on which is better, optical or digital coax?
