Product Details: This loader we assume that soon,will be the Unit to P4-P5 card, We are in Test. If you have any Questions please e-mail us True universal ISO-7816 - 1/2/3 compatibility On board hardware based universal smart card reader/writer Microsoft PC/SC compatible (USCT PC/SC Driver Required) . On board universal smart card diagnostic and recovery system On board Atmel AT90S2313-10PI Micro-controller For P4-P5 card Test AT90S8515-10PI. On board (ICP) Atmel programming interface. Will gain entry to cards previously untouchable by *old* code Future Unlock updates for Unlocking future Dealer Lock down 3M scripts One unit, one mode, does it all without any re-flashing. Provides the solution for cards that won't open with existing loaders and programming. Repairs otherwise un-glitchable card. One switch mode selection. All matched and hand selected device components No hardware device drivers needed in direct RS-232 mode Supports all speeds of serial communication up to 115,000 baud Compatible with all MCU smart cards and most Memory Only cards Compatible with all RS-232 smart card development software Supports both commercial and military power specifications Only true hardware based universal all-in-one S-C terminal available Amphenol "snap-in" card slot rated at 200K+ insertions Incorporates the exclusive and convenient SDLOGIC ON/OFF switch Incorporates a 20-pin dip socket for easy removal of Atmel chip Incorporates a 4 position switch selector for modifiable timing slopes Incorporates the proven SDLOGIC INTERSIL RS232 Chip Incorporates a new heavy duty DC jack Incorporates a new surface mount heavy duty voltage regulator Incorporates (5) separate Philips74Hc4053N Separate mode indicators Atmel Pin 1 Jumper Enable/Disable /Bridge. Enhanced high-speed buffer circuitry support (Jumper Enable/Disable) New anti-static/chemical coating treatment to the Amphenol card slots
