Multiple Satellites On Same Dish
Very Thankful
I have a Directv RCA dish. Can I get a dual LNB and a disq switch to receive 110 and 119 using the same dish and 1 coax down to the FTA receiver?
Thanks for any help that can be provided.
No ur gonna have to buy a new dish with dual lnb.s if u want both sats or put up another dave dish. heard of one guy who taped another lnb to the dave dish and says it works ok
Very Thankful
Thanks for the info. So, what type of dish should I buy and can I use a disq switch to maintain only 1 coax to the receiver?
Very Thankful
I saw a DiSEqC 1.2 MOTORIZED H-H Mount on ebay. Can I hook this up to receive 3 satellites using the dave dish?
VT buy a dish that has a dual LNB, use a 4 port disq switch, use your direct dish for bev and the dual dish for charlie,and yes u can maintain one line to the ird, but u have to get 3 pcs. of cable about 6 ft between lnbs. and switch...if u use a hh mount how u gonna change the az....there are alot of dual lnb dishes that will work but avoid the ones with a switch built in...
Very Thankful
Anonymous, perfect. so, the dual dish I buy - is there a specific make I should look for? I always thought dual lnb meant you could connect to 2 receivers but this sounds like 2 satellites to 1 receiver off 1 dish (i hope)...
Very Thankful
squirrel
Get Oval DTV dish (not round) with 2 lnb's and align the 119 and 110 satellite for Dishnetwork and round single DTV dish for Bev.
shimya
i use a direct tv dish for dishnetwork.. i align one lnb for 119...then I velcro and tape another lnb for 110.. works fine for me.
VT there's a twin lnb which is what u were refering to and then there's a dual for two seperate sats.check out this site their legit, but can't u buy a dish locally, u live in T>O there's lot's of places or check out the buy an sell newspaper or website...later
VT sorry forgot to give website incredibledss.ca just a bit hung over...later
LeafsRule
I have my Pansat 2500A receiver hooked up to my DirectTV dish.It's aimed at Expressvu sattelite but I get a lot of bad or scrambled channels, what could be the problem? Thanks
Leafs bev's been screwing around the past couple days rescan an u should be fine
