RE BLACKBIRD RECEIVER
Username: Andy99
has anyone puchased one of these is it true you need no card. any feedback woud be great
ANDY THEY WORK BUT I RECOMEND THE PANSAT 2500 IT KICKS.......I HAVE A SYSTEM FOR SALE THE RECIEVER DISH AND LNB READY TO WATCH TV.....525 DELIVERED USA OR CANADA JMILL1948@AOL.COM
I would like to know if anyone has had any knowledge about the Blackbird receiver. Does it work as advertized? Is it easy to set up? Any info would be appreciated. Thanks
like i said the pansat is the one to get preprogramed with lots of support..... check out jmill . the blackbird on the other hand has gone up in price pansats are going up to since fta is about the only way left to easy test....gami32
Username: Jmatarazzo
Post Number: 8
hello i have the pansat 2500(off ebay for 230 delivered. not 525)what is the process of set up.their instructions blow.do you need to keep installing software,or updates?is there a website that has better help?also.what is a good type of dish to use(besides the t-55 superdish)i already have a dtv dish aimed already for dtv.(im in rhode island)any help would be great.
thanks
Blackbird works great I use it actually too k about two days to get eveything set the way I wanted I am recieving a little over 1000 channels now local for just about every city in the US The you know what selection... is outstanding. The only real pain in the !#!%# is the fact it does not name all the channeles correctly when doing Sat Scan. I use a Wineguard Dish w/DG-2100 H-H motor with my old direct TV LNB it can track 7 sat easily currently I have three proggrammed for 1000 channel more tv than I can watch
Check out http://forums.al7bar.tk they have lots of information on all the FTA, blackbird, pansat etc... receivers, get honest opinions from people actually using them!
Username: Jmill1948
Chester, Va Usa
Post Number: 63
YES FTA IS THE WAY TO GO IF YOU NEED HELP GIVE ME A SHOUT.BUMP........J JMILL1948@AOL.COM
charles perlman
the forums over at dsshelper.com are replete with an enormous amount of info on FTA receivers
they have foums dedicated to several didferent makes and models of FTA units
im about to order my second receiver now that i learned how i can test two Pansats with one dish
Rflan1
Does anyone have info on hooking up more than one tv to the receiver? I have been seeing "UHF Ready" and "IR Ready" in some of the ads. Can anyone expand on this?
I need some help with my blackbird receiver. I just purchased a blackbird and the instruction I find about it on the net does not have match what is showing on my screen. For example it says to go to Installation then select Dish setup. My menu does not have dish setup but other options such as antenna. Can anyone help. I also need a site where I can find keys and software I guess but don't know what to do with it.
Please help, thanks.
ocram
Blackbird - I think I need to flash it. Can anyone help me with it. I need to know the name of the software to use and the name of the software to flash it with. You can email me at marc@lambton.on.ca
Thanks
my receiver went out and now i cant get nothing but the green light on front....it wont pick up connect to pc or anything any body know whats going on or how to fix it?
i am having the same problem as i was updating the power was diconnected .turned it back on the green lite was on but unresponsive. any suggestions Walt at Waltkboom@aol.com
a friend
for anyone who has the blackbird you will need to wait for the site to upgrade software blackbird will tune some channels meanwhile but it takes long to tune in.
ocram
Still need help. I am trying to flash my blackbird but keep getting "Connection Failed" when I try to connect to com port1 or 2.
Can anyone help. Thanks
marc@lambton.on.ca
arniesr
After installing upgrade software to my enforcer it wont keep the keys I program into it when I leave the PFF panel. Also does not say "dish network" below the keys as it did before. Anybody know the fix??
Username: Dss2092
Post Number: 21
Hi Guys, I have all this stuff for sale at some great prices...just log into www.DssBliss.com
Here is a list of items !
Thanks
www.DssBliss.com
DSS REV --- 74.99
XTREEME ROM A3B --- 59.99
ATMEGA 128 + J-TAG COMBO --- 99.99
ATMEGA 128 + J-TAG + DIGILOCK COMBO --- 119.99
DSS REV & EXTREME ISO COMBO --- 129.99
ATMEGA + J-TAG + NAGLESS LOCK COMBO --- 119.99
ATMega 128 --- 44.99
AVR6 --- 34.99
TSOP 3 Chip Lock --- 19.99
TSOP 2 Chip Lock --- 19.99
J-31 JTAG & Cable --- 49.99
Universal JTAG & Cable --- 49.99
Xtreme ISO Programmer --- 59.99
TSOP Nagless Lock --- 19.99
DSSREV ISO Programmer --- 59.99
Universal Atmega 18x PLL --- 44.99
Digital Lock Auto Rest V2.0 --- 19.99
Magic Card w/Programmer --- 84.99
Quad ISO --- 59.99
Xtreme SureShot Serial --- 59.99
Xtreme SureShot USB --- 79.99
Mikobu III --- 79.99
Absolute 1 --- 59.99
T-911 --- 59.99
No 745 Wafer --- 79.99
No 745 Red Devil --- 79.99
Xtreme Red Dragon --- 59.99
__________________
Lowest price or we beat it !!!
DssBliss
LUCY
HI, GUYS, NEED SOME HELP I JUST BOUGHT MINI-BLABKBIRD REC. BRAND NEW FROM E-BAY BUT DON'T KNOW HOW TO MAKE IT WORK ...THANKS
LUCY20@MYWAY.COM
Lucy starting from scratch I'd be here all day,go to a fta site like al7bar.ca or try incredibledss.ca they have a quick set up guide for BB then if u need anymore help come back an ask...later
