Elevate Your Maggies with Magna Risers
Looking to improve the quality of your Magnepan loudspeakers? Magna Risers might be the ultimate accessory for our favorite high-end loudspeakers.
Magna Risers 2nd Airborne for Magnepan LRS Loudspeakers
It might shock some people to learn that the Magnepan LRS are my daily drivers. Yes — these $650 loudspeakers are my benchmark for affordable high-end loudspeakers and it’s not something that is going to change anytime soon. I’m almost two years into my journey with these exceptional loudspeakers and while I think I have them mostly figured out, there are some areas where they can be improved.
I do drive them with two amplifiers that are slightly out of whack considering the price differential, but the sound quality makes me listen well into the early hours. The Cambridge Audio Edge A and Schiit Audio Ragnarok 2 sound so good with these speakers, but I can understand why some would take issue with me using a $6,000 amplifier with $650 speakers. I purchased one before the other thinking I was going to end up with a very different pair of loudspeakers — but things just worked out this way.
I do plan on trying the new NAD M23 with the Maggies but that will also require a preamplifier and DAC; something both the Edge A and Ragnarok 2 offer.
If you’ve ever wondered what all of the high-end loudspeaker fuss is all about, you owe it to yourself to audition a pair of Magnepan LRS speakers. Or any other loudspeaker from the Minnesota-based manufacturer. Magnepan is rapidly approaching 50 years in the game and that makes them one of the oldest and most successful loudspeaker companies in the world.
I’ve vacillated back and forth between Magnepan and MartinLogan for almost 30 years, but the LRS have become my daily driver. Did I mention that they are only $650? If I have one complaint (and it’s honestly the only one) with the LRS it is 100% the base and feet (I’m being kind calling them that). Enter Magna Risers.
Magna Risers 2nd Airborne with Magnepan LRS Loudspeakers
The LRS are planar loudspeakers; sound is reproduced out of both the front and rear of the enclosure. Magneplanars don’t suffer from the “boxy” sound that plagues traditional loudspeakers because they don’t have a box. There is no cabinet.
The panel is framed on either side with a very thin wood border but the absence of a cabinet does something very special with music.
Transparency. Clarity. An almost see-through quality with music that will blow your mind if the speakers are setup properly and the amp can deliver enough current.
Power and current are not the same thing. Stick with a class AB amplifier than can double its output into 4 ohms and you should be fine.
NAD, Schiit Audio, Emotiva, Audio Research, Bryston, and Pass Labs all work exceptionally well with Maggies.
Magnepan LRS Speakers in room
Original stands with Magnepan LRS Loudspeakers
Back to the feet. Brutal. I understand trying to keep the manufacturing costs down but a major negative for such an incredible loudspeaker.
There have been 3rd party risers/feet and stands available for all of the Magnepan models for many years; they provide better stability, tighten up the bass, and improve the overall resolution of the loudspeaker.
Maggies are not bass monsters so anything that can tighten up the bass and bolster its impact is a win.
The LRS have a degree of tilt with the stock feet and they certainly benefit from being completely perpendicular to the floor. Imaging and clarity improve.
One of the keys to getting great sound out of the LRS is proper setup; the inner portion of the panel need to be further from your ears than the outside edge. In my particular room, the bass ribbon is 2-inches closer to my listening position than the tweeter portion.
You also need to position any pair of Maggies 3 feet (at a minimum) from the wall behind them.
All of this requires a better pair of stands. Both in terms of setup (you can slide these back closer to the wall when not listening) and getting the most out of these speakers.
$650 speakers that sound more like $2,000 speakers and I may be insulting the LRS in that regard.
One of the things that I love about the Magnepan community is that owners share their experiences with amplifiers and accessories and it was through them that I was introduced to the folks at Magna Risers who manufacture these amazing stands.
I’m pulling out the wallet and ordering a pair without any previous demonstration because I’ve heard from enough Maggie owners that they work really well.
Each Magna Risers stand uses the existing mounting holes on the back of every Magnepan model to make installation easy.
The stands were designed to maximize the sonic performance while also allowing the speakers to be easily moved by not adding excessive weight. The LRS are very slim panels but they’re anything but lightweight.
The Magna Risers are constructed from high quality metals that are nearly indestructible and the stands are finished in an attractive high-gloss commercial powder coat to provide a durable finish.
The waiting list for the various stands is pretty long but we’re getting in line and hope to have a review soon.
For more information: magnarisers.com
Related reading: Magnepan LRS: Audiophile System Builder
7 Comments
7 Comments
  1. leo
    April 22, 2021 at 6:46 pm
    There are FOUR WAYS to setup panels.
    You apparently come from the ‘tweeter in’ school. But to get the tweeter further away, you need a LOT of toe. That can hurt imaging.
    Tweeters OUT are the 2nd way…..
    Than you can FLIP the panel and listen to the Pole Piece side. Magnepan did the flip themselves back in the 90s……Before that? My MG-1 panels were marked L/R and were pole piece to the listener.
    • Ian White
      April 22, 2021 at 10:15 pm
      Leo,
      I’ve listened with both the tweeter on the inside/outside and I’m “tweeter in” all the way.
      Ian
      • leo
        September 4, 2021 at 12:43 am
        Now you need to FLIP ‘Em Around and try the pole piece side.
        the only fully symmetric Maggis are the 20 and presumabely the 30 series which have a pole piece on BOTH sides, making them true push-pull designs…
        My original panels were MG1 and were intended to be pole-piece TO the listener. This changed maybe in the 90s sometime and now Maggies come with the mylar to the listener and pole-piece to the ‘wall’….My MG1 were helped in VERY small rooms by swapping them L/R. They came labed L/R from the factory.
      • Funnyname
        January 27, 2022 at 5:49 pm
        If you really want to elevate the LRS speakers, order the upgrade kit from gr-research.
        And amplification from Hegel works wonderful as well.
        I have the tweeter’s on the outside, i like the bigger soundstage and sweet spot that way.
        • Ian White
          January 27, 2022 at 6:42 pm
          I tried them both ways and I’m definitely an “inside” guy. That sounded wrong.
          I’m aiming to try them with the NAD M23 and one of the Master Series Pre/DACs this quarter.
          I’ve watched Danny’s video 3 times and I am convinced that I will ruin my pair of LRS because I have zero desire to take them apart.
          Ian
          • geoffrey
            September 25, 2022 at 7:04 am
            Hello,
            Get the m33 instead😉.
            G
  2. Ron
    September 25, 2022 at 10:12 pm
    Magnepan is offering a “riser” option with the new LRS+…and cloth with no wood bordering along the edge.
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
Our favorite floorstanding loudspeakers to buy in 2024 are from Bowers & Wilkins, JBL, Magnepan, Q Acoustics, SVS and Zu Audio,
The definitive buying guide to the best bookshelf speakers from $300 to $1,400. Our picks from the best high-end brands.
A/V Furniture & Accessories
Thinking of replacing your existing loudspeakers? The IsoAcoustics GAIA III Speaker Isolation Feet might force you to change your mind and save money as...
Just add in-ceiling speakers to Q Acoustics 300A Ceiling Amplifier to bring streaming music and Amazon Alexa into any room.
JBL raises the bar for affordable stereo and home theater performance with stylish lines of A/V receivers and matching loudspeakers.
Priced from $2,250 to $7,000 per pair, Monitor Audio's Gold Series 6G loudspeakers include six models for stereo or home theater setups.
