Best Wireless Noise Cancelling Headphones: 2022 Buying Guide
Our picks for the best wireless noise cancelling headphones to buy in 2022 at various price points may surprise you.
2022 Best Wireless Noise Cancelling Headphones
Update: Click here for our latest Editors’ Choice Awards for Wireless Headphones. Some products mentioned below may no longer be available and pricing may have changed since originally published in October 21, 2022.
What’s the Best?
People love to toss that term around a lot. Best. The reality is that no publication can listen to every product in a category, but over the past year we have listened to dozens of ANC wireless headphones and some are clearly much better than others. Our selections are taken from that rather broad list of options and none of the selections should be a surprise.
The good news is that the performance gap is narrowing and that there is something for everyone at multiple price points.
Readers ask us one basic question — “Which one should I get?”
The truthful answer is that it really depends on your budget, listening behavior, and what kind of sources are you going to use.
It’s a bit like going to a Chevy dealer and asking the salesperson which car you should get. You could realistically drive away in anything from a Corvette to a Suburban.
You need to ask yourself some honest questions before you spend $200 to $999.95 USD on a pair of ANC wireless headphones. Don’t be seduced by the brand names or aesthetics.
Criteria
  • Cost
  • Features
  • Comfort
  • Usability
  • Build quality
  • Battery life
  • ANC Performance
Sound quality and ANC performance are the two most important criteria; battery performance, comfort levels, and usability need to be factored in as well. There are very few wireless headphones in this category in 2022 that are poorly made.
All products generally involve some compromise to reach a price point. The best choice for each listener may be the product that strikes the best balance or the product that emphasizes the listener’s top priority. We’ve listed our favorites below along with worthy alternatives should your grading system be a bit different than ours.
Best Budget Wireless Headphones
1More SonoFlow Wireless ANC Headphones Angle
1More SonoFlow
The 1More Sonoflow offer a lot of features for only $99. Bluetooth supports multipoint and LDAC in addition to SBC and AAC.  Battery life is nearly 70 hours (verified) and the headphone will work powered off via a 3.5mm auxiliary cable if needed. Sound is better than expected at the price and the 1More app is among the best for tuning options so users can tweak the sound to their liking. 1More’s version of ANC is adequate to very good as well.
Pros: Affordable, build quality, sound quality, case, portability
Cons: ANC falls behind others, controls are a bit finicky
Where to buy: $99.99 at Amazon | 1More.com | Amazon.ca
Cleer Enduro 100 Wireless Headphones Navy
Honorable mention: Cleer Enduro 100
The Cleer Enduro 100 ($99) doesn’t have ANC, but offers an even longer battery life (100 hours) and similar sound quality to the SonoFlow. The trade-off is the Cleer’s App doesn’t have quite as many tuning options.
Stepping up in price enters a very crowded space, which makes it hard to pick without knowing which discounts are active. For example, the Cleer Alpha ($220) would be a good alternative to the Enduro or SonoFlow models. However, at over double the price, the differences may not be enough to justify the cost for many.
Where to buy: $99.99 at Amazon | Cleeraudio.com
Best Value Wireless Headphones
Shure AONIC 50 Wireless Noise Cancelling Headphones in Brown
Shure AONIC 50 in brown (also available in black)
Shure AONIC 50
The best all-around affordable wireless headphone is the Shure Aonic 50 ($299). It combines good sound with adequate ANC, LDAC support, and good battery life.
Pros:  Great build quality and sound, good battery life and solid controls
Cons: ANC is not as good in the higher frequencies as Sony/Bose offerings
Where to buy$299 at Amazon | Shure.com
Bose QuietComfort 45 Black
Honorable Mention: Bose QuiteComfort 45
The Bose QuietComfort 45 ($329), is a worthy alternative to the Shure Aonic 50 with better ANC and nearly equal sound quality but loses out on build quality which is largely plastic and lacks aptX and LDAC support.
Where to buy$329 at Bose.com | Crutchfield | Amazon | Amazon.ca | Amazon.co.uk
Best Headphones for Noise Cancellation
Sony WH-1000XM5 Wireless Noise-Cancelling Headphones Angle
Sony WH-1000XM5
If you need to have the best ANC possible, be prepared to shell out $400 on the Sony WH-1000XM5. Yes, they are pricey, but they have the best ANC we’ve tested to date, good connectivity options, and solid sound quality and battery life. If you can survive with slightly inferior ANC performance, the Bose NCH 700 ($399) is more intuitive in its controls and offers better comfort.
The Sennheiser Momentum 4 ($350) offers slightly better sound quality at the expense of its ANC performance. The build quality is slightly disappointing on both the Sony and Sennheiser as both use more plastic than we’d like in the construction; the Bose NCH 700 takes the prize for design and build quality.
Pros: Best ANC on the market currently, good battery life, solid sound signature, good comfort
Cons: Plain design, sound is impacted by ANC
Where to buy$399 at Amazon | Crutchfield | Amazon.ca | Amazon.co.uk
Honorable mention: Bose QuietComfort 45
Bose and Sony have taken turns taking the ANC crown from each other with each leapfrogging the current king with their new releases. While Sony currently holds the title, the QC45 came dangerously close to dethroning it and honestly the choice between these two models comes down to personal preference with our decision influenced by overall build quality; the QC45 is mostly plastic and just doesn’t feel as upscale as the current Sony.
Best Wireless Headphones Without ANC
Edifier Stax Spirit S3 Wireless Headphones
For those that don’t care about noise cancellation, there are a few options with sound quality at the top of their class. Both happen to use planar magnetic technology which can often reveal a bit more detail.
The Edifier Stax Spirit S3 ($399) provides a good mix of passive isolation from its ear cups alone with excellent sound quality that rivals the Sony and Bose. It’s easy to drive as well, and portable, which means it would work well with your smartphone.
Pros: Fit, build quality, sound quality, driver technology
Cons: Does not offer ANC, bass response lacks impact
Where to buy$399 at Amazon | Edifier.com
HiFiMAN DEVA Pro Wireless Headphones with Bluemini connected
Honorable mention: HiFiMAN Deva Pro
The HiFiMAN Deva Pro ($329, w/Bluemini R2R Wireless unit) is an open-back wireless headphone with excellent sound. It can be slightly clunky to use with the detachable BlueMini adapter and is not ideally suited for travel due to its open-back design. Sound quality for the price will be tough to beat.
Where to buy: $329 at Amazon
Best Overall ANC Wireless Headphone
Bowers & Wilkins PX7 S2 Wireless Headphones in Black, Blue and Grey
Bowers & Wilkins Px7 S2
The best overall headphone at $400 is the Bowers & Wilkins Px7 S2. It’s priced the same as the Sony WH-1000XM5, but there is no question that the Px7 S2 has superior sound and build quality, and looks like a pair of high-end headphones. The industrial design is the best in the category and its ANC performance only trails the category-leading Sony by a very small margin. If you are looking for a pair of ANC wireless headphones that will make a statement — the blue finish will certainly turn some heads on the street.
Pros:  Great build quality, solid ANC performance, sound quality that rivals some more expensive models
Cons: ANC performance with high frequency noise is inferior to top models from Sony and Bose.
Where to buy$399 at bowerswilkins.com | Amazon | Crutchfield
Bose Noise Cancelling Headphones 700
Honorable mention: Bose Noise Cancelling Headphone 700
Although the Bose Noise Cancelling Headphones 700 (NCH 700) are not new, they offer the best design and have dead simple touch/swipe controls. They make for a great travel companion with good sound, usable ANC, above average battery life, a great aesthetic, and controls that won’t leave you frustrated. The ANC performance of the Bose QC45 is superior but we still prefer the NCH 700 more.
Where to buy: $379 at Bose.com | Amazon | Crutchfield
Best High-End Wireless Headphones
Focal Bathys Wireless ANC Headphone
Focal Bathys
Focal’s first wireless noise cancelling headphones have set the category on fire, and this is one of those rare products where the hype is warranted. The Bathys are audiophile quality headphones that sound significantly better than the competition between $400 and $700. The linear tonal balance and presentation makes them extremely engaging and they offer excellent resolution and detail retrieval.
The build quality and comfort level are what you should expect from wireless headphones that cost $800.
The sound signature is typical of Focal’s house sound with a mild lift in the mid-bass to add warmth and a mild lift in the upper midrange/lower treble to bring vocals to the forefront. The controls on the Bathys are intuitive and easy to use and its companion app provides access to all the key features in a couple of clicks.
Pros: Best sound quality of any wireless headphone we have ever tested. Build quality is superb.
Cons: ANC performance is behind Sony and Bose. Cost.
Where to buy$799 at Crutchfield | Amazon | Amazon.ca
Mark Levinson No. 5909 Wireless Noise Cancelling Headphones in radiant red
Honorable mentionMark Levinson No. 5909
The Mark Levinson No. 5909 is another audiophile headphone, which happens to be the most expensive headphone on our list. Their tuning matches the Harman target curve to a degree few have been able to achieve (even better than Focal) and provide a great listening experience for casual listening.
The build quality is very high, but we are not sold on the aesthetic design which doesn’t feel like a $999 pair of headphones. The Bathys just offer a better overall experience.
Where to buy$999 at Crutchfield | Audio Advice
Master & Dynamic MW75 Wireless Noise-cancelling Headphones Silver and Brown
Honorable mention: Master & Dynamic MW75
The Master & Dynamic MW75 are a step above the B&W Px7 S2 and a step below the Bathys and Levinson No.5909 in price and offer some of the features from both levels. The build quality rivals the higher end models, while the sound quality is a bit closer to the Px7 S2 than the Bathys or No.5909. ANC performance is solid but not decidedly better than the Sony or Bose for the additional money. The highlights of the MW75 are the sound and build quality. If you need a high-end ANC headphone that can handle more bumps and bruises than the rest of the models in the category — the MW75 are a top pick.
Where to buy: $599 at MasterDynamic.com | MasterDynamic.co.uk | MasterDynamic.eu
Final Thoughts
While we strived to put together the best options, the list grows daily and it is entirely possible some new model will come along and change our thinking. The most notable changes over the past 12 months have been the improvements in battery life, sound quality, and ANC performance. If Focal, Bowers & Wilkins, and Sennheiser can improve the ANC capabilities of their new models — Sony and Bose are going to start losing market share.
Holiday sales are approaching and it is likely that you will find some of these excellent ANC wireless headphones on sale before Christmas.
Note: The Bowers & Wilkins Px8 (2022 model, $799) and Bang & Olufsen H95 (2020 model, $899) have not been tested yet.
Go deeper: Watch us on YouTube discuss all of the winners.
While I got author credit on this piece, it was a team effort with contributions by Brian, Ian, and Lynn in addition to my thoughts. Thanks to all who contributed.
Update: Pricing and availability may have changed since our story originally published on October 21, 2022. Find our most recent Editors’ Choice Awards for Wireless Headphones or view all Editors’ Choice categories.
7 Comments
7 Comments
  1. ORT
    October 21, 2022 at 5:36 pm
    I fully expected to see a pair of the coolest lookin’, kinda-sorta-inexpensive ‘phone on the planet – Teh Meters Music OV-1 with…VU Meters in the cups!!
    Having said my druthers I shall admit to lusting for the Focal Bathyspheres. Style is back in style, my friends.
    Right now via my Momentum 3s, deep inside my head Buddy Clark is singing one of my all-time favourite songs.
    “Linda”
    Kinda-Sorta makes me want to cue up “Laura” on my 400 Disc Blu-Ray Sony. Gene Tierney is gorgeous. Buy the Bathyspheres lads and then listen to what for me is Darin’s coolest song, “Mack The Knife”.
    I think I just got something in my eye…Or is it in my soul?
    ORT
  2. David
    November 1, 2022 at 4:06 pm
    This is a very helpful comparison of the latest offerings at different price points. Would like to ask a follow-up question:
    I work from home and use headphones for numerous calls per day. Accordingly, my priorities for a headset are (in order): 1) Call/voice clarity, 2) comfort, and 3) sound quality. The thing is, I don’t want to compromise too much on #3 to get the other two. Based on a call quality emphasis, which headphones would be your recommendations at the $300 and $400 price points? I read the detailed reviews of all the headphones you cover in this video, but most of the reviews (some, but not all) don’t spend much time on call-quality assessment.
    And, in case you are going to suggest high-quality earbuds, I’m perfectly happy to consider those…..when I can find a #%$%& pair that will actually stay in my ears when I turn my head 2-3″ in either direction. 🙂
    Thanks in advance for your counsel, -dGB
    • ORT
      November 3, 2022 at 10:20 am
      David, I would seek out a pair of Sennheiser Momentum 3s. Best Buy still has them for $250 and I think, not feel, they off the best music reproduction of the lot at the price point you set and they work just fine for calls. I speak with my mother, my older sister and at least one of my brothers daily via either the QC45s or the Momentum 3s. No problemo at all.
      Back to the Momentum 3s. I own them and I also own Bose QC45s and have bought and returned Sennheiser PCX 550IIs and the fourth iteration of the Sonys. The Bose QC45s are very, very good with holding a Bluetooth signal (much better than the others mentioned but then I use signal booster and with that can easily listen from up to 100 feet!) and reproduce music better than two of the three I just mentioned. When it comes to music, the Momentum 3s do the Bose one better. And they are better looking than all of them at, again, your price point. Both the Senns and the Bose are comfortable for all day wear but again, for music the Momentum 3s reign supreme.
      The choice is your, my friend. For even (Ahem! Slightly) better looks and from what the lads say here, superb performance, the B&Q Px7 S2 are nonpareil, again in your price range.
      In Blueish.
      Oh. And it probably goes with out saying but I am not one of the excellent reviewers here at Ecoustics. I’m just a toad that could not sleep this night and who likes music and ‘phones. I am wearing the Momentum 3s as I write this. 🙂
      In all ways and for always, be well.
      ORT
  3. ORT
    November 4, 2022 at 8:01 pm
    I just ordered a Pair of Blueish B&W Px& S2 ‘phones. So David, as I have trusted the words of these gentlemen so too can you. I do NOT buy junque, neither for my self nor family and friends.
    I shall try to convey these minimalist “thoughts” of mine sans my usual dour humour.
    That they are not exactly worthy of KAVOD, still would I think them more often than not, well intended and “enough”. I try and Hmmm…. These ain’t heavy…They’re my headphones.
    And like Joni’s album, they are Blueish.
    ORT
  4. Pat
    December 21, 2022 at 4:17 pm
    I would have enjoyed seeing KEF’s new cups on this list. I’m looking for more reviews to validate before purchase.
    • Ian White
      December 21, 2022 at 5:43 pm
      Pat,
      KEF have yet to send a pair for review but we’ll keep on them.
      Best,
      Ian White
  5. Zorq
    December 31, 2022 at 1:05 pm
    Good list, sensible reviews. As a matter of fact, the Bathys track the Harman curve even better than the 5909. As for sound, both are better than the rest, in different ways.
HDTV 4K & 8K TV
Last month, we got a sneak peek at Sony’s new BRAVIA 4K TVs. Here’s what’s coming down the pike this year.
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Can the first child of Audeze and Sony be a sonic superman for only $150? The Sony Pulse Elite is for more than just...
Over-Ear Headphones
Find out if the HiFiMAN HE1000 Unveiled open-back audiophile headphones sound good enough to appease those worried about its exposed drivers?
March has been a busy month for new headphone introductions, including the Focal Bathys MG and Meze Audio POET.
HDTV 4K & 8K TV
There's a new OLED TV in town and it's sure to be a top contender for best TV of 2025.
