Best Audiophile Turntables Under $2,000 in 2023
Our favorite audiophile turntables in 2023 include Pro-Ject, Rega, Technics, Orbit and more.
Best Audiophile Turntables Under $2,000 for 2024
Update: Find the latest Audiophile Turntable Editors’ Choice awards here. Some products mentioned below may no longer be available and pricing may have changed since originally published in late 2023.
Are you considering a turntable upgrade in 2024? Before you empty your wallet on a deck that might seem like the right path for you — we have a few suggestions that might make more sense long-term if your budget is between $600 and $2,000.
Audiophile Entry-Level (Below $600)
Andover Audio SpinDeck Max Turntable White
Andover Audio SpinDeck Max Automatic Turntable ($599)
There is a lot of competition below $600 and I was fortunate last year to try a number from Rega, Pro-Ject, Fluance, and Andover Audio. The level of performance that can be squeezed out of an entry-level deck is surprising, but for most people — they just want to set it up and listen.
I wasn’t really blown away by the SpinDeck but the SpinDeck Max is a completely different table that is manufactured in Germany for Andover. The automatic design just feels more substantial and it’s built to a much higher standard; which includes the tonearm and rather beefy platter.
The supplied Ortofon OM10 is fine but I swapped it out for a Grado Prestige Red3 which just sounds fuller and less bright in my office system. The SpinDeck Max is not a fancy deck but it comes across as slightly more authoritative sounding with excellent pace in most systems. It can also be tweaked with a cork platter from Analog Restorations and certainly benefits from some isolation. You might be surprised at what this deck can do with a better cartridge and phono preamplifier.
Where to buy: $599 $399 at andoveraudio.com | Amazon
Audiophile Mid-Tier
Pro-ject Debut Pro Turntable Front Lid Open
Pro-Ject Debut Pro
Pro-Ject Debut PRO ($999)
Having spent three months with the Debut Pro which proved to be one of my favorite products of 2022, I’m more than confident to recommend it to anyone in the $1,000 range. Inflation has pushed everything higher but I’d still spend the extra money on this one.
Having compared the Debut Pro to all 6 tables that I have at home which includes the aforementioned Thorens decks, a NAD C 588, Yamaha YP-701, and a mystery deck that is currently under review — the Debut Pro is an excellent deck that can be tweaked to a very high level of performance. Consider this to be the best currently available under $1,000.
Pro-Ject has the ability to manufacture almost anything and the new tonearm and very inert platter elevate this table in a very substantial way; it sounds far more forceful and dynamic compared to the Debut EVO tables that lack some bottom end weight and presence in comparison.
The supplied Sumiko cartridge works well but swapping that out for the Sumiko Wellfleet or Blue Point No. 3 is a very worthwhile upgrade.
Read my Pro-Ject Debut Pro review here or watch our video review here.
Pros:
  • Excellent build quality
  • Can be upgraded with a better cartridge, platter mat, and isolation platforms
  • High quality tonearm
  • Forceful and dynamic sounding
  • Does not sound or feel entry-level
Cons:
  • Supplied cartridge screams for an upgrade
  • Not inexpensive
  • Will force you to upgrade your phono pre-amplifier
Where to buy$999 at Amazon | Crutchfield | Turntable Lab
U-Turn Audio Theory Turntable Walnut Angle
U-Turn Audio Theory Turntable in Walnut
U-Turn Audio Orbit Theory ($999)
The little engine that could is tucked away in a suburb outside of Boston, and after almost 10 years old it is hard not to be impressed by what Ben Carter and the folks at U-Turn Audio have accomplished.
The new U-Turn Audio Orbit Theory Turntable is a huge milestone for the company that has focused on the market below $400 for most of their existence.
When I visited the company almost 7 years ago, it was impossible not to notice that they were struggling with the sheer volume of orders and that they needed to find better domestic sources for their platters, plinths, and motors.
Carter and I discussed the rationale for the price structure of their tables and the possibility of manufacturing something in the $700 USD range.
There was already the desire to make something like the Orbit Theory and take on Rega and Pro-Ject, but that required more capital, employees, and the ability to create a tonearm that would be a major upgrade over the tonearm on the existing Orbit.
U-Turn Audio Theory Turntable Walnut Lifestyle
The new U-Turn Audio Orbit Theory is $999 USD — you can also order a version with their internal phono stage for $1,069.
The focus with the new Orbit Theory is clearly on the tonearm, motor, and construction of the plinth.
For the Theory Orbit turntable, U-Turn decided that they needed to take their OA2 gimbal bearing design to the next level by further reducing points of resonance in the tonearm. Practically speaking, this meant using more rigid materials and minimizing the number of connection points between parts.
The new motor and pulley are so quiet that they can be mounted directly to the plinth, ensuring perfect belt alignment. The motor is electronically controlled by a DC-powered sine wave generator – this provides very stable platter speed and gives you the ability to change between 33/45 RPM with the turn of a knob.
Theory’s acrylic platter is frosted, and all of platter surfaces have been precision machined for maximal flatness and minimal runout. They have also machined a groove into the platter to keep the belt in place.
What better way to celebrate a new turntable than with a new finish? For Theory, U-Turn decided to do real hardwood plinths, but wanted to spice things up a bit. Ebonization is a traditional finishing process that turns wood black without staining or painting.
How does it sound?
Bold. Precise. Far more substantial than any of the decks they have produced before and with excellent tonal weight and speed.
Where to buy: $999 at uturnaudio.com
Audiophile High-End ($1,200+)
Technics SL-1500C-K Turntable Black
Technics SL-1500C-K
Technics SL-1500C Direct Drive ($1,299)
Technics has been very aggressive during the vinyl revolution introducing a number of new models that have sold out in some markets within weeks. The brand has a proven track record with both DJs and audiophiles and even its top models that sell for more than $3,000 USD have continued to sell well.
The SL-1500C sits in the middle of the Technics product lineup and has been available since 2019. However, looks like it isn’t going away anytime soon as Technics, instead of offering to replace it has decided to offer a new color option in addition to the standard silver and black, the SL-1500C will also be available in matte white (SL-1500C-W).
With its minimalistic look, the SL-1500C-W is designed for great performance and ease of use supported by the following key features.
The SL-1500C-W incorporates a coreless direct drive brushless DC motor. This allows for a stable rotation that is free from “cogging.”
The two-layer platter provides improved vibration-damping performance.
The highly sensitive S-shaped aluminum tonearm accurately reads record grooves; an S-Shaped tonearm has an equal mass on both sides of its pivot point.
In addition to its S-shape the tone features Auto-lift. This minimizes needle wear-out and preserves records.
The SL-1500C-W has a high-rigidity cabinet and a high-damping insulator for the thorough shut-out of vibrations. This ensures smooth tracking.
What makes this deck unique?
Fantastic speed stability, combined with rather rugged construction and a solid tonearm make it a reliable platform for a wide range of cartridges. We’ve listened to this range of decks with Ortofon, Hana, Grado, and Golding cartridges and you might be surprised how well it performs with $750 to $2,000 cartridges. It also elevates the performance of less expensive cartridges making it a great platform that you can upgrade over time.
Where to buy: $1,299 at Crutchfield in black (SL-1500C-K), silver (SL-1500C-S), or white (SL-1500C-W)
Rega Planar 3 50th Anniversary Turntable
Rega Planar 3 50th Anniversary ($1,695)
Rega’s iconic turntables have been in production for 50 years and would make any credible list of high-end audio components that have changed the industry. Rega has also sold hundreds of thousands of tonearms over the past 5 decades; audiophiles have purchased OEM versions of its tonearms from a number of brands including Michell, Origin Live, Moth Audio, and Goldring.
In 1977, Rega introduced the Planar 2 and Planar 3 turntables, which were an evolution of the Planet turntable. The Planar 3 was designed to be a higher-end version of the Planar 2, with better build quality and performance.
The Planar 3 had a glass platter, a low-noise motor, and a new tonearm. The new Rega-Acos R200 tonearm was a radical departure from the standard tonearms of the time.
It was a lightweight design that used a unipivot bearing, which allowed it to track the record groove more accurately. The Planar 3 was an instant success and quickly gained a reputation for its excellent sound quality and value for money.
Over the years, Rega has continued to refine and improve the Planar 3 turntable. In 1983, they introduced the RB300 tonearm, which was a significant upgrade over the original tonearm. The RB300 used a more rigid tube and a more advanced bearing system, which improved tracking accuracy and reduced distortion.
In 1991, Rega introduced the P3 turntable, which was an updated version of the Planar 3 with a new motor, platter, and tonearm. In 2000, Rega introduced the P3-24, which had a new 24-volt motor and a new plinth design.
In 2016, Rega introduced a new version of the Planar 3, which had a new RB330 tonearm, a new plinth design, and improved motor control circuitry.
Rega Planar 3 50th Anniversary Edition Turntable Lid Closed
Available in the hugely popular new walnut effect finish, the 50th anniversary Planar 3 is supplied with a hand tuned Neo PSU MK2 and the handmade Rega Exact moving magnet cartridge factory fitted.
For those looking to upgrade this Planar 3, there is a new cartridge option just released by Rega at High End Munich 2024 that looks like a big upgrade over the Exact.
According to Rega, the Nd3 will offer between 5 and 6mV of output (which feels somewhat ambiguous) and requires 1.75 grams of tracking force. The headshell uses 3 points for attachment making it ideal for Rega’s own tonearms.
Each Nd3 is hand-made by Rega’s skilled technicians in the UK factory. The design uses brand new generator geometry with perfect symmetry to achieve highly accurate channel balance. The Nd3 also has an optimized pole gap for superior linearity and cross talk characteristics.
The complete assembly is housed in a zero tolerance Injection moulded glass filled polyphenylene sulphide body (PPS) which is a lightweight and highly rigid material. A low mass body reduces stress on the tonearm bearings and aids free movement which is critical in accurate vinyl replay.
This new body design was inspired by Rega’s existing range of MC cartridges.
The drive system uses their reference drive belt and a custom CNC’d aluminium drive pulley to deliver the absolute best in performance and accuracy.
The Anniversary Edition is completed with an aluminium lid plinth badge and smoked dustcover to complete the Anniversary Edition.
What makes this deck special?
If you put enormous value on tempo, clarity, detail, and a very open sounding presentation — the Rega is very hard to beat.
The expressive nature of this deck is second-to-none at the price.
Pros:
  • Pacing, detail, and clarity are excellent
  • High quality tonearm, platter, and plinth
  • Music has an additional level of flow and presence that is hard to deny
  • New Nd3 cartridge is an upgrade
Cons:
  • Needs better isolation
  • Not inexpensive
  • Glass platter needs a better quality mat
Where to buy: $1,695 at Music Direct (limited availability)
Tip: The regular Planar 3 (without cartridge) starts at $1,125 at Turntable Lab and Audio Advice
Pro-Ject X2 B Turntable Walnut
Pro-Ject X2 B
Pro-Ject X2 B ($1,799)
Does balanced really make a difference?
My experience suggests that it does if you have to contend with certain noise issues.
Almost 22 years ago, I invested in a very expensive turntable and felt that I had reached vinyl nirvana. I paid a professional $200 to properly install the cartridge, setup the table which had a finicky suspension system, and help me mount the turntable shelf to the wall.
My building at the time was a pre-war in downtown Toronto that needed an upgrade on the electrical front. Noisy to say the least.
No matter what I tried, my turntable setup always sounded noisy; ground loop issues, constant hiss, and it became a a source of depression (first world problems). Why bother spending almost $8,000 on such a system if it sounded terrible.
A local dealer suggested that I have my arm and table modified so that I could run a fully balanced rig; which also included upgrading to a balanced phono stage. I sold a few other items to facilitate the changes.
Extreme? Perhaps.
But when I listened to the same records that mattered to me — I was stunned by the differences in clarity, noise floor, and overall dynamics of the sound.
Does a balanced setup always sound better? Not necessarily and I’m not convinced that every manufacturer who markets “balanced” is really offering that.
Pro-Ject Balanced Turntable connected to Phono Box S3
The Pro-Ject X2 B offers both single-ended and balanced connection options, but you do need to use an MC cartridge for a balanced setup.
Is there a huge gap between the Debut PRO and the X2 B? Fair question.
If running the same MM cartridge like a Sumiko Wellfleet, I would still give the edge to the X2 B when it comes to impact and overall resolution, but the gap isn’t enormous.
However, when running a MC cartridge into one of the Pro-Ject balanced phono pre-amplifiers or something like the Moon by Simaudio 610LP — the gap between the two tables is rather enormous.
The clarity, bass impact, soundstage depth and width, and overall dynamics of the system totally changes.
The Pro-Ject X2 B goes from being a very good $1,799 turntable to a rather exceptional table that can compete with some tables in the $2,500 to $3,000 range and I’ve heard enough $3,000 tables to know. Read my in-depth review here.
Where to buy: $1,799 $1,599 at Amazon | Turntable Lab
HDTV 4K & 8K TV
After a shocking 145% tariff on Chinese imports, new U.S. Customs guidance spares smartphones, laptops, and TVs—giving tech giants like Apple a much-needed breather...
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
$449 or $599, find out which Sumiko moving magnet phono cartridge is right for you?
Ask an Expert
If you can't get picture or sound from your TV or projector don't despair. Here are some debugging tips from our resident home theater...
The Quality of Physical Media, The Convenience of Digital Download.
Updated with a new die-cast aluminium platter, Pick It MM E phono cartridge and other refinements, the Automat 1.2 might be the most logical...
Rega's forthcoming Brio MK7 Integrated Amplifier will be available this month and is creating a stir with its internal DAC for only $1095.
Pro-Ject's Artist Series of turntables has expanded with a new offering paying homage to the legendary band from down under. The price might leave...
