Best Desktop Headphone Stands of 2025: Top Picks for Audiophiles & Gamers
Discover the 8 best headphone stands for 2025—engineered for durability, stability, and style. These top-rated options support all headphone types and won’t break the bank.
Best Headphone Stands
Regardless of how much money you have to spend on a pair of headphones, there is an argument to be made that you need to take care of your investment. The explosive growth of the headphone market over the past decade has created a real need for headphone stands; especially when some are spending up to $6,000 on a single pair and want immediate access on the desktop and a better way to maintain their shape.
A headphone stand keeps your gear safe, organized, and within reach—preventing damage, cable tangles, and clutter. Available in materials like plastic, metal, or wood, they range from minimalist to decorative, with options for desk-mounted or freestanding designs. Whether you want sleek functionality or something that complements your setup, there’s a stand that fits.
Some even offer extras like cable management, USB charging, or even LED lighting.
While many brands make decent stands, not all can handle the weight of larger audiophile over-ear models. That’s why we recommend sturdy options like the Sieveking Sound Omega—built to last, unlike the endless stream of flimsy knock-offs flooding Amazon.
Our “Best” options range from relatively affordable to rather pricey but all of them offer durability, quality construction, and work well on the desktop.
Key Features to Look for in Audiophile Headphone Stands:
  • Build Quality: High-end materials like aluminum, wood, or stainless steel are often preferred for their durability and aesthetics.
  • Stability: Ensure the stand has a solid base, especially if your headphones are large or heavy.
  • Protection: Look for stands with padding or a smooth finish to avoid any damage to the headphones’ headbands or ear cups.
  • Design: The stand should complement the sleek, high-quality design of audiophile headphones, so consider something minimalistic, elegant, and functional.
New Bee Headphone Stand
Best for: Those on a budget looking for an affordable option that is stable.
Why choose it?
The New Bee Headphone Stand is a budget-friendly option that is made of durable plastic and features a simple, no-frills design. It is compatible with most headphone styles and comes in several colors. Not for heavier audiophile over-ear models like Audeze LCD-X or Meze Empyrean.
$8.99 at Amazon
AmoVee Acrylic Headphone Stand
Best for: Perfect for those looking for a way to reduce clutter and keep gaming headphones off the floor.
Why choose it?
The AmoVee Acrylic Headphone Stand is a clear, minimalist stand that is designed to showcase your headphones. It is made of high-quality acrylic and features a non-slip base to keep your headphones secure. Perfect for smaller headphones on a kid’s desk.
$14.59 at Amazon
Yamazaki Headphone Stand
Best for: Those seeking a modern and clean stand that is surprisingly heavy and very affordable. Will work with mediums-sized headphones.
Why choose it?
It is very hard to go wrong with this $28 headphone stand; the thick steel base can support relatively heavy headphones and we really like the simplicity of the design. The Yamazaki does not offer any charging options or storage but that would be asking a lot from such an inexpensive stand.
$28.50 at Amazon
Brainwavz BigT Dual Headphone Stand
brainwavz-bigt-dual
Best for: Those who are challenged for space on the desktop and want easy access to 2 pairs of headphones.
Why choose it?
This sleek, minimalist hanger now holds two headphones and is built from high-grade plastic, secured with ultra-strong 3M VHB tape. The BigT can easily support up to 5 pounds—because even your heaviest cans deserve a solid place to hang.
$16.99 at Amazon
Razer Base Station V2 Chroma
Razer Base Station Chroma V2 headphone stand white
Best for: Those requiring desktop charging and a wider perch for bigger headbands.
Why choose it?
Razer is best known for its gaming headsets and soundbars designed for the desktop, so we expected something substantial from them when it came to a headphone stand. The Base Station V2 Chroma does not disappoint with its detachable base, RGB lighting, two USB 3.1 ports, & one 3.5mm combo port with built-in DAC with 7.1 surround sound. What is also notable is its ability to handle headbands up to 50mm in width which makes it compatible a surprising number of audiophile headphones and headsets.
$59.99 at Amazon
Sieveking Sound Omega Headphone Stand
Sieveking Sound Omega Headphone Stand in Zebra
Best for: Full-sized planar magnetic, dynamic or electrostatic headphones that require a heavier base.
Why choose it?
Sieveking Sound produces handcrafted wooden headphone stands that are both functional and aesthetically pleasing. Their stands come in a variety of finishes and are designed to fit a wide range of headphones, and can be customized with a personalized engraving. The Maserati Grecale Trofeo of headphone stands.
$199 at moon-audio.com
2 Comments
2 Comments
  1. ORT
    May 5, 2023 at 1:58 pm
    Ian –
    These stands look nice and I certainly could use one or two, until then I keep many my ‘phones in their respective case and two are out for use on a wall hanger/hook of sorts. Thank you for this article on them!
    ORT
    • Picklgreen
      May 23, 2025 at 7:34 am
      You missed some of the absolute best stands available made by woo audio! They make a single and dual model. Its a sturdy adjustable design with a curved design that wont leave a crease on the headband like some of those other stands.
      https://wooaudio.com/accessories/hps
First previewed at the 2026 CES and High End Vienna under the Atlas name, Klipsch brings the final versions of the HP-2 and HP-3...
After extensive listening with dozens of models, here's the best open-back and closed-back wired headphones for audiophiles in 2026.
Check out our favorite wired over-ear open-back and closed-back headphones for audiophiles and studio professionals at various price points.
The best wireless headphones of 2026, tested by eCoustics. Our Editors’ Choice picks from Sony, Bose, Focal, DALI and more cover ANC, sound and...
Grado's $295 Signature S150 brings a new 44mm driver, detachable cables, and improved comfort to its open-back headphones.
Movies
THX Deep Note returns with “Spark,” a new trailer that updates a 42-year cinema ritual for today’s immersive moviegoing experience.
Klipsch Atlas headphones make their EU debut in Vienna, but HP-2 and HP-3 won’t ship until Fall 2026.
