Ryan R610 Speakers: The Audiophile System Builder
Are the Ryan R610 one of the most underrated bookshelf or stand-mounted loudspeakers around? You would be amazed what these can sound like with the right system.
Ryan R610 Bookshelf Loudspeaker Closeup
Do you remember your first pair of loudspeakers? The Ryan R610 speakers were not my first but I would have been content with them being the last pair of loudspeakers I purchased.
I remember lugging a pair of Celestion Ditton 33 MK II loudspeakers upstairs from my parent’s living room in 1983 and feeling the burn in my arms. The chunky bookshelf speakers were a 3-way design with a new type of super tweeter and ring compression driver. Not that hard to drive but definitely on the cooler side from a tonal perspective. The Celestion were 35 pounds and extremely inert.
A Yamaha CA-2010 integrated amplifier drove them for almost 10 years, and I still remember watching a clumsy mover drop them accidentally on 62nd Street in New York City.
Do you remember John Belushi’s expression from Animal House when a clumsy mover dropped his last case of beer following the expulsion of Delta House from Faber?
Almost verbatim.
Wharfedale have tapped into that segment of the market who love larger bookshelf loudspeakers with their best-selling Linton Heritage speakers and there is a lot to love about the design and their creative stands that must be considered mandatory.
Multiple pairs of Wharfedale loudspeakers were glaring at me in my home office the night as I moved the Ryan R610’s into position.
Ryan R610 Bookshelf Loudspeaker Front
The Ryan R610s are not new loudspeakers but they remain in production and have flown under the radar for almost 8 years; a circumstance that I find utterly ridiculous.
At 16.73″H x 8.86″ W x 12.1″ D, the R610s are considerably larger than most two-way speakers and rather heavy at 33 pounds. Use both hands when placing on your speaker stands or you will be sorry. I have huge mitts and made sure to insert some of my fingers into the rear port to make sure they couldn’t tumble off the top plate which isn’t that large.
The height of the R610s did force me try different types of set-ups because my 24″ single-post GHA steel stands set the tweeter quite high (even for a 6’3″ listener such as myself) in relation to my listening position. I experimented with the R610s on a CB2 media console with a height of 21″ and turned sideways on an inverted IKEA Kallax which is set 7 feet in front of my home office desk.
Regardless of how you set them up, ensure that the stand or base that they sit on is quite inert.
Ryan R610 Bookshelf Loudspeaker Rear
I do own multiple sets of IsoAcoustics speaker stands which allow you to place bookshelf loudspeakers on a media unit or desktop – but I found that they did not improve the sound in a way that I liked; the Ryan R610s can be ruthlessly revealing depending on the rest of the system and the stands made them sound somewhat sterile; these are definitely loudspeakers that will reward you when you select wisely or punish with the wrong amplifier.
The Ryan R610 speakers need at least two feet from the wall behind them. I would also heed the advice of Todd Ryan and place them at least 7′ apart and then angle them in towards your head. I’m not obsessed with the width/depth of the soundstage, but the R610s reproduce it well with proper placement.
The 6.5” woofer driver employs a laminated Nomex cone to minimize breakup and ringing throughout its frequency range and beyond. The design of the woofers motor and suspension was perfected using the Klippel Distortion Analyzer. Mrs. Klippel must be very proud.
The 1” tweeter utilizes a proprietary treated cloth dome sourced in Japan. Ryan has gone old school with the tweeter by applying a felt ring to the front surface of the tweeter; it looked odd at first, but it does help to minimize early reflections and the proof is in the listening.
Unlimited Power
The Ryan R610 speakers are rated at 86dB (8 ohms) and they don’t represent the most difficult load but my experience with them suggests that they do better with 50 – 100 watts (or more) than with lower powered tube amplifiers. I have run them with 8 watts of SET amplification and while the sound quality was divine, they ran out of gas very quickly.
They definitely sound better with more power and they certainly need an amplifier with meat on the bones.
Cambridge Audio Evo CD Player Black Angle with Streamer Stack
I wondered about the Cambridge Audio Evo 150 Network Amplifier and Unison Research Simply 845.
Both amplifiers have the right tonal balance and power output to make these loudspeakers work.
Unison Research Simply 845 Integrated Amplifier with CD Uno CD Player
The Cambridge will deliver a lot more power and greater control in the low end, whilst the Simply 845 will tame the top end, create spooky imagery, and add layers of texture and presence to the music.
Sources
Pro-Ject X2 B Turntable with the Sumiko Blue Point No.3 (high output) MC cartridge works very well with the Pro-Ject Tube Box DS2 phono pre-amplifier.
The digital front end really depends on which amplifier you select; the Evo 150 has a hi-res streamer and very good DAC inside.
The Unison Research will require something like the Cambridge Audio MXN10 as a starting block for your Spotify, Qobuz, and TIDAL subscriptions.
One advantage of the Evo 150 is that one can add the Evo CD transport if you have a large CD collection.
The Sound
Bold. Textured. Midrange resolution that puts a lot more expensive loudspeakers to shame.
The Ryan R610s are for people who desperately want to imagine that the vocalist is in the room with them, but that has to include scale, imaging, and a very airy sounding treble that never gets hard.
You can play these loudspeakers quite loudly and the soundstage won’t collapse when things get very complex and you want to feel the impact of the piano or bass guitar.
I’ve spent well over 200 hours listening to the Ryan R610’s in my den (16′ x 13′ x 9′) and I’m under 10 feet from the front of the loudspeakers. I’ve never felt the need to turn the volume up past conversation levels and thought that I’m losing anything. With a warm sounding amplifier, these loudspeakers can be downright spooky good.
If you listen to techno, synth-pop, classical, jazz, blues, and pop — these speakers can create some very memorable moments. Not ideal for heavy metal; I’ve run AC/DC, Iron Maiden, and Metallica through them and it never really made my heart race.
The No. 19
Sandwich
Don’t ask. Just eat. Definitely not kosher. I will deny ever eating in this L.A. establishment. Someone had to do it. So much flavor. So much humanity.
Ryan R610 Speakers ($2,000/pair)
Cambridge Audio Evo 150 Network Player
or
Pro-Ject X2 B Turntable and Sumiko Blue Point No.3 High Output Moving Coil Cartridge
Pro-Ject Tube Box DS2 Phono Pre-Amp ($900 at Amazon)
Cambridge Audio MXN10 Network Player
14 Comments
14 Comments
  1. Sean
    April 20, 2021 at 12:38 pm
    Watching the used market, Ryan speakers rarely come up for sale and I think that says a lot about them. They aren’t flashy, don’t really leap out at you, and are like a good wife/partner, they are in it for the long haul. I’ve owned my R630s now almost longer than any other speaker. I’ve realized there might be speakers that do one or two things better but overall, they are hard to beat.
    • Ian White
      April 20, 2021 at 1:08 pm
      Sean,
      I agree. the R610s are one of my favorite loudspeakers on the market. Just so underrated.
      Ian
  2. Steven O'Farrell
    September 24, 2021 at 6:06 pm
    Its nice to see audio products that are under-appreciated be featured and reviewed. This review gave me insight into this speaker, and I hope to have an opportunity to hear them at some point. The “vocalist in the room” attribute gets me every time, and is something i look for, listen for when auditioning speakers. Nice review; please keep an eye out for other great gear that are underayed/fly below the radar, but shouldn’t!
    • Ian White
      September 24, 2021 at 6:43 pm
      Steven,
      Greatly appreciate the kind words. Ryan makes really good speakers. The audio press were very interested in this brand and then completely forgot about them. The R610 are one of my favorite speakers and I think they are worth every cent. I wish they were better with 2-3 watts from something like the Decware SuperZen Triode but that’s asking a lot of them unless your room is really small. I’ve used an 8-watt SET amplifier with them and they kicked serious ass in my 16 x 13 x 9 den sitting around 8 feet back from the front of the speakers.
      Best,
      Ian White
  3. Guy Boisvert
    December 21, 2023 at 5:03 pm
    I own those speakers since 2018. I bought it with Rega Elex-R and Rega Dac-R. It was the kit i chose after listening to many much more expensive. For the money, this kit was a clear winner.
    After, i upgraded my dac to an Ayre QB-9, the sound indeed improved showing the speakers could do more!
    This year, i sold the Rega Elex-R and the Ayre QB-9, replacing them with Hypex Nilai 500 Stereo DIY, Hyper Preamp DIY and Topping D70 Pro: The full potential of those Rega R610 is unleashed!!! Incredible sound for such an affordable price, kudos to Ryan brothers!
    • Ian White
      December 21, 2023 at 5:10 pm
      Guy,
      They are superb loudspeakers. Sound incredible with tubes.
      Glad you are enjoying them so much.
      Best,
      Ian White
  4. Asa
    January 11, 2024 at 4:42 pm
    If you’re ever in Palm Springs, Sherman’s is a great kosher deli!
    Will these work for a desktop/work listening setup, or would it be overkill? Sounds like they’d be perfect for ambient/techno I listen to a lot while working.
    Thanks for all the diverse/humble/extreme equipment reviews – makes for quite a musical array.
    • Ian White
      January 11, 2024 at 6:13 pm
      Asa,
      I tried them that way and way too much. It was overwhelming.
      They are really good with ambient and techno. Smooth, clean, and very punchy with the right amplifier.
      The issue with them is the amplifier; they can be so ruthlessly revealing with the wrong gear. Darker sounding SS or tubes are the way to go.
      I tried them with a KT88 SET amplifier and it was incredible but they ran out of steam very quickly.
      Shermans. I will write that one down.
      Ian
  5. Sean
    January 11, 2024 at 6:19 pm
    I owned the R630s and the Ryan Brothers really build some great sounding and exceptionly built speakers. I sold them to go back to planar speakers and have some regrets since I practically gave them away. I’ll have add them to the long “The one that got away” list. There were a few years they were popular with the YouTube crowd but seem to no longer be FOTM. I noticed the new Genesis Series 7speakers have allot of resemblances, anyone know if Ryan is building the cabinets for them?
  6. Doug
    January 14, 2024 at 6:01 pm
    “ the audio press forgot about them”
    I also remember when there was a positive murmur about around ten years ago or less about this brand then. … poof.
    Anyway great review and great product.
    • Ian White
      January 14, 2024 at 7:53 pm
      Doug,
      Agreed. They made very fine loudspeakers. I know two tube amplifier manufacturers that use a pair of their floor standing models at home as a point of reference. These are definitely used speakers to look for.
      Best,
      Ian White
  7. Carl
    January 17, 2024 at 5:30 am
    OMG, how I long for Langer’s.
  8. Adam
    January 25, 2024 at 7:40 pm
    I’ve seen these come up at great values in the used market. Considering these vs the PSB B600 you gave a great review of for a second system in my office. I have a Line Magnetic LM845 premium amp as my main amp but also looking at a solid state amp, but looking for the speaker first. Do you have a preference between the PSB or Ryan? I like a natural sound with great imaging and staging. Have 2 REL S510’s and an extra Sumiko 12″ sub I will probably integrate into the system, so deep bass is covered, but if I don’t need to put the sub in the room that’s good too. Any thoughts? Thanks for your valued opinion!
    • Ian White
      January 27, 2024 at 2:18 pm
      Adam,
      I would go with the Ryan R610s. Superior treble and I like the concept of an 845 with these a lot. If I can find a pair in good shape used, I may bite and use the Unison Research Simply 845 with it.
      Best,
      Ian White
$449 or $599, find out which Sumiko moving magnet phono cartridge is right for you?
Larger cabinet, bi-wiring, new crossover, and reengineered bass port are only some of the changes for the new Triangle BOREA BR04 which will retail...
Our favorite integrated amplifiers in 2024 include models from Cambridge Audio, Naim, NAD, Unison Research and more.
The Best Audiophile CD Players of 2024 include Hegel, Luxman, Marantz, Rotel and more for the ultimate in compact disc playback.
