The 12 Best Affordable Phono Cartridges to Upgrade Your Turntable: Editor’s Choice 2024
Get the best sound from your turntable by upgrading its phono cartridge. Our buying guide cuts through the noise with purchasing options for any budget.
Best Affordable Phono Cartridges 2024
Jump ahead:
If you are in the market for an affordable audiophile turntable, or replacement cartridge, it’s easy to get lost looking through the hundreds of affordable phono cartridges that are available. Deciding if you want a moving coil or moving magnet (or moving iron if select one from Grado Labs) cartridge is just one part of the decision making process.
Compatibility with the tonearm is also something that you need to pay attention to; just because you want to mount a specific cartridge on your turntable doesn’t mean that you should without checking with the manufacturer or dealer for advice.
Many entry-level turntables come with a pre-installed cartridge from Audio-Technica, Grado Labs, Sumiko, or Ortofon. Aside from confirming the tracking weight and that the anti-skate is properly set, you’re usually only a few minutes from listening to records in this scenario.
But if you’re looking to upgrade what you already own or don’t love the sound from the pre-installed cartridge on your new table, these are very worthy alternatives and excellent value for the money.
But if you want to elevate the level of playback quality from your records, there are a number of options below $800 that extract a lot more information from the grooves and help shape the tonal presentation of the music.
Your choice of phono pre-amplifier will also impact the overall sound quality in a significant way.
Do not spend more on the cartridge than the table. Even a restored vintage turntable with the right arm will maximize sound quality with even an inexpensive moving magnet cartridge like a Nagaoka MP-110 – versus a $800 Dynavector on an entry-level turntable.
Proper set-up of your cartridge is more important than what you spend. Clean your records and your stylus. Nothing ruins a stylus faster than dirty records.
12 Phono Cartridges You Need to Consider
Nagaoka MP-110 Phono Cartridge
Nagaoka MP-110 ($133)
Japanese manufacturer, Nagaoka, has been manufacturing outstanding moving magnet phono cartridges for almost 70 years. The entry-level MP-110 is an excellent tracker digging into worn out grooves with authority and delivers a very open and detailed sounding presentation across the entire frequency spectrum. The 5mV output is on the high side, but that also makes it compatible with a wide range of phono pre-amplifiers.
The cartridge is a good match on both entry-level and more expensive turntables and offers a lot of performance in a Rega, Pro-Ject, or SME tonearm for under $150. It may not be as popular as the 2M Red from Ortofon which shows up pre-installed on a lot of entry-level tables, but it offers a smoother ride and with less top end bite.
Pros:
  • Excellent tracker
  • Very detailed and open presentation
  • Entry-level price for one of the best below $250
  • Smoother sounding than Ortofon 2M Red
Cons:
  • Will make you want to try the more expensive Nagaoka MMs leaving you with less money to spend on records
  • Revealing nature highlights every imperfection or scratch
  • Could be slightly warmer sounding
For more information: nagaoka.eu
Where to buy:
Audio-Technica AT-VM95ML Phono Cartridge
Audio-Technica AT-VM95ML ($169)
Looking through their extensive lineup of phono cartridges can be somewhat confusing, but Audio-Technica have some really affordable cartridges below $200 that really shine on a better table. Install on something entry-level, and the sound will be fine but nothing really special considering how much potential lurks inside the cartridge body. But which one should you buy and do they really sound all that different? Not only do they sound different, but the type and shape of the stylus will have a huge impact on the sound. Even at this price level.
The AT-VM95ML is a moving magnet cartridge with a microlinear stylus and rather quiet in the grooves. The 3.5mV output makes it compatible with most internal phono preamps that you’ll find in your receiver or integrated amplifier, and it has excellent channel separation.
It’s not the warmest cartridge that we’ve ever heard so pair it with a warm sounding phono preamp or amplifier. Detail freaks will love this cart. Bass freaks will find it somewhat lean and quick sounding in the lower registers. It’s a clean sounding cart that has a little more emphasis in the treble than the Sumiko Wellfleet.
Pros:
  • Very quiet in the grooves making it a great entry-level cartridge
  • High output
  • For detail freaks
  • Excellent value for the money
  • Excellent stereo separation
Cons:
  • Some may find it to be too neutral with a lean sounding system
  • Lean bass range
  • Needs a warmer sounding phono pre-amplifier
  • Entry-level tables may put on a spotlight on its detail and top end emphasis
For more information: audio-technica.com
Where to buy:
Goldring E4 Phono Cartridge Front Underside
Goldring E4 ($299)
Some cartridges fly under the radar because the brand doesn’t get them into the hands of enough members of the press or because the price doesn’t create enough buzz in comparison to rivals. Goldring have been in business almost as long as Danish rival, Ortofon, and that puts them in rather elite company.
The Goldring E Series are natural rivals to anything Audio-Technica and Ortofon have to offer below $300 and the E4 might best them all. I’ve been listening for the past month (the E4 replaced both the Ortofon 2M Red and Golding E3 on my NAD table) and it’s not even close.
The Goldring E4 is designed to be compatible with all medium-to-high-mass tonearms of the type found on the majority of budget to midrange turntables.
What’s different about the new E4?
The super-elliptical nude diamond stylus features lower effective tip mass, and improved rigidity, which should result in better high frequency detail retrieval than ‘bonded’ elliptical alternatives.
The E4 features a ‘nude’ super-elliptical stylus of just 7.6 x 18 microns (0.3 x 0.7 mil), which is cut and polished from a single homogeneous piece of diamond.
To complement its low tip-mass stylus, the E4 now features a hollow aluminum cantilever tube.
The Goldring E4 delivers a more open and neutral sounding presentation with a wider soundstage. It is also easier to sculpt into a very specific type of sound which will appeal to those who use vintage receivers or amplifiers, or entry-level integrated amplifiers below $1,000 than often veer to the darker side.
Combine all of that with excellent speed, timing, and resolution and you have one of the best sounding entry-level phono cartridges available below $300.
Pros:
  • Easy to install
  • Superb value for the money
  • Detail retrieval is excellent
  • Wide soundstage
  • Transparent and very open sounding
  • Highlights the pace and timing of every piece of music
  • Ideal for older vintage amplifiers with a more organic tone
Cons:
  • Some may find it to be lacking in color
  • Revealing nature will be too much in cooler sounding systems
  • Needs a medium to high mass tonearm
For more information: Read our Goldring E4 Review.
Where to buy:
Grado Timbre Opus3 Phono Cartridge
Grado Labs Timbre Opus3 ($300)
Grado does offer some rather expensive phono cartridges but the vast majority of its sales are below $300 and products like the Opus3 make one question why you need to spend a lot more; I have always believed that it makes more sense to buy a better table and use an overachieving cartridge like the Grado Labs Opus3, Denon DL-103, Nagaoka MP-110, or Ortofon 2M Bronze instead.
The Opus3 is nestled inside a Maple housing (8 grams) and I discovered that it sounded the best on my vintage Yamaha YP-701 and the replacement Ortofon LH-2000 Headshell that was ordered during the pandemic for another cartridge.
The cantilever is made from aluminum and the Opus3 uses an elliptical diamond stylus; mounting the cartridge was quite easy and I settled on a tracking force of 1.8 grams which was within the range but closer to the very top.
Grado offers multiple versions of the Opus3 including the high output (4mV) version supplied, a low output model (1.0mV), and a mono version as well.
The Grado does vocals about as well as any $200 – $300 phono cartridge on the market and it doesn’t matter if you’re listening to Amy Winehouse, Sarah Vaughan, Alison Moyet, Sia, Orville Peck, or Jason Isbell.
Presence, tone, texture, and detail have to be present or it’s just some flat rendition of something that doesn’t engage you at all. The Grado Labs Opus3 succeeds in every way with the kind of vocals that I enjoy listening to and that makes it a keeper.
If your budget ceiling is $300, the Grado Labs Timbre Opus3 is definitely a high-output cartridge to seriously consider.
Pros:
  • Presence, tone, texture and detail retrieval are on full display
  • Well made
  • High level of resolution that is not common below $300
  • Superb at making vocals come alive
  • Strong with jazz, rock, and pop music
Cons:
  • Wood body may not be the easiest to mount on some tonearms
  • Can hum slightly on older Thorens tables with metal platters
  • Needs a better table and phono preamplifier to show off its strengths
For more information: gradolabs.com
Where to buy:
Rega Nd3 Moving Magnet Phono Cartridge Side
Rega Nd3 ($345)
When Rega launched its affordable Nd3 MM cartridge at HIGH END Munich 2024, the rather inexpensive entry-level cartridge did not get a lot of attention. That’s a pity because it’s very good for less than £175. We are slightly confused in regard to its $345 USD price but that’s what it is retailing for here now.
Planar 2 and Planar 3 owners now have a new option and it will become the standard cartridge to ship with both turntables.
The Nd3 offers between 5 and 6mV of output (which feels somewhat ambiguous) and requires 1.75 grams of tracking force. The headshell uses 3 points for attachment making it ideal for Rega’s own tonearms.
Often used in Moving Coil designs (including their own), Rega believe that the Nd3 is the first moving magnet to utilize a Neodymium (Nd) N55 magnet.
The Nd3 aluminium cantilever is fitted with a precision elliptical stylus. This profile provides exceptional tracking accuracy and extracts great levels of detail from the vinyl surface.
How does it sound?
Detailed, clean, surprisingly punchy in the upper bass and lower midrange if your system leans somewhat on the darker side, and a very good tracker. Rega’s trademark speed and timing is clearly evident and it was incredibly easy to mount on a Rega tonearm.
Pros:
  • Strong value for the money
  • Detailed and very transparent sounding
  • Good tracker
  • Very easy to install on Rega tonearms
Cons:
  • Needs to be used on Rega tonearm to maximize its performance
For more information: rega.co.uk/products/nd3
Where to buy:
Denon DL-103 Phono Cartridge
Denon DL-103 ($349)
Denon introduced the DL-103 in 1962 for professional broadcast use, and it has proven to be of the most popular and reliable phono cartridges of its kind. The low output moving coil design (0.3mV) requires a higher mass tonearm; opening the door to used Fidelity Research, SME, or EMT arms or more expensive modern arms from Kuzma, or Jelco (which recently decided to cease production). Jazz listeners have long prized the DL-103’s tonal balance and open presentation that make both brass instruments and vocals come alive.
The DL-103 requires at least 60 dB of gain to come alive; sticking a step-up transformer between the affordable DL-103 and the moving magnet input of your phono stage can be a transformative experience when everything is set-up correctly. Third party manufacturers have been offering modified DL-103 variants for the past few years at considerable expense, but our advice would be to stick with the stock model from Denon.
Pros:
  • One of the most successful MC cartridges of all-time designed for broadcast use
  • Consistently good with all kinds of music
  • Tonal balance and open presentation make it the best cartridge for jazz
  • Excellent pacing
  • Performance can be taken to another level with a step-up transformer
Cons:
  • Requires a higher mass tonearm
  • Low output requires 60 dB of gain
  • Needs a better quality table and phono preamp to show off its magic
For more information: denon.com
Where to buy:
Ortofon 2m Bronze Phono Cartridge
Ortofon 2M Bronze ($429)
A century of cartridge development expertise and manufacturing has to count for something so it’s not surprising to see at least one cartridge from the Danish manufacturer on our list. Ortofon offers a wide range of cartridges from under $100 to almost $10,500 for the Anna MC cartridge, but our favorite affordable model from their line-up is the 2M Bronze.
The 2M Red comes pre-installed on a lot of entry-level turntables but we think the additional $375 is well worth it for a lot of reasons. The 5mV output makes it compatible with almost every available external phono pre-amplifier and integrated amplifier, and it’s extremely easy to install – although those who are thinking about installing it on a Rega tonearm will require spacers to achieve the correct set-up height.
The 2M Bronze delivers tonal accuracy, pace, and a boldness that love with tube pre-amplifiers or warming sounding systems. Imaging is excellent, and the top end is far smoother sounding than the 2M Red.
We’ve long believed that a better table is more important than spending a fortune on a cartridge and the 2M Bronze is a decided overachiever on expensive turntables. You may listen and decide that your records have never sounded any better.
Pros:
  • One of the best cartridges below $500
  • Resolution, clarity, and tonal accuracy are excellent
  • Solid tracker
  • Dynamic and fast sounding
  • Solid imaging
Cons:
  • Rega tonearms may require spacers
  • Requires a high-end turntable and pre-amplifier to show off what it can do
  • May be too much in an overly neutral sounding system
For more information: ortofon.com
Where to buy:
Sumiko Wellfleet MM Phono Cartridge Angle
Sumiko Wellfleet
Sumiko Wellfleet ($449)
Sumiko offers an extensive lineup of both moving coil and moving magnet cartridges; a number of models come pre-installed on Pro-Ject tables being distributed in North America and they represent a great starting point for those getting started with listening to vinyl.
Having reviewed a number of Pro-Ject’s better turntables between $1,000 and $1,700, it became apparent during our listening sessions that the Wellfleet offers a rather significant uptick in performance for less than $500.
The $449 Sumiko Wellfleet MM Cartridge pushes that price ceiling higher but the early word is that the new nude 0.3 x 0.7mil elliptical stylus MM cartridge is quite the overachiever below $500 — which puts it in direct competition with the Ortofon 2M Bronze, Nagaoka MP-200, and Grado Labs Timbre Series Platinum3 cartridges.
The Wellfleet is crafted by hand in Yokohama, Japan (and that applies to every cartridge in the Oyster and Reference ranges), and offers 3 mV of output — which is on the lower end of the range for a MM cartridge. The 6.5 gram cartridge has a recommended tracking force range of 1.8g – 2.2g — 2 grams offered the best balance on a wide range of tonearms.
Extremely transparent, punchy, a solid tracker on dirty records, and a nice layer of warmth without becoming guilty of excessive coloration in the mid bass and midrange.
Pacing with jazz and rock recordings is a definite strength.
Pros:
  • Solid build quality
  • Tracks well in the groove
  • Easy to install
  • Transparent and punchy sounding presentation
  • Pacing with jazz and rock recordings is excellent
Cons:
  • Low output for a MM cartridge
  • Not inexpensive
  • Needs a better turntable and phono preamplifier to show off its capabilities
For more information: sumikophonocartridges.com
Where to buy:
Hana EL Phono Cartridge
Hana EL ($475)
Hana’s parent company has been an OEM manufacturer for a number of prestigious Japanese phono cartridge brands for years, but the decision to enter the marketplace with their own cartridges under the “Hana” label has been a huge success so far.
Hana offers three tiers of phono cartridges; creating some welcome competition for Ortofon, Grado, and Audio-Technica, and it is the low-output EL (0.5mV) utilizing an elliptical stylus that shines the brightest with a quality moving coil phono pre-amplifier.
It is also not the hardest cartridge to install and works superbly well on a wide range of tables including a restored Thorens TD-160 Super or TD-125 from Vinyl Nirvana.
An excellent tracker, the EL offers a lush sounding midrange, and slightly rolled-off treble making it an excellent cartridge with a wide range of music and systems. Partnered with a phono pre-amplifier from iFi Audio or Moon by SimAudio, the Hana EL can deliver a lot of performance for only $475.
Pros:
  • Not difficult to install
  • Works well on higher end turntables
  • Very good tracker
  • Lush sounding midrange
Cons:
  • Warmer tonal balance requires a more analytical sounding preamplifier or loudspeakers
  • Treble is slightly rolled-off
  • Requires a high-end table and phono pre-amplifier to show off its capabilities
For more information: musicalsurroundings.com
Where to buy:
Sumiko Blue Point No. 3 High Output MC Phono Cartridge Front
Sumiko Blue Point No.3 ($499)
Eric Pye did a wonderful job reviewing the Blue Point No. 3 and his observations about its pacing and organic nature piqued my interest. We both share a similar obsession with jazz music and he’s never steered me wrong in regard to great music suggestions.
Eric ran the Sumiko on a vintage Denon DP-1200, whilst I chose to run the Blue Point No. 3 on both Pro-Ject tables and ultimately felt that the more expensive X2 B was a marginally better platform.
The new Blue Point No. 3 cartridges were announced in June 2021, replacing the best-selling Blue Point No. 2, for an affordable ($499.00 each) MC design that produces great detail and stereo separation.
Both cartridges benefit from a new shell design, with a smoothly bevelled front fascia allowing excellent visibility of the stylus tip when mounting.
Pro-Ject offers the Blue Point No. 3 in both high output (2.5mV) and low output (0.5mV) versions.
Superb stereo separation combined with the most natural sounding detail is a huge selling point.
The bass range is tight and quick, but delivered with less impact than its rival from Brooklyn.
With a tonal balance that is somewhere in-between the Goldring and Grado, the Japanese cartridge is likely the best all-around for those looking for detail, texture, pacing, and overall top end performance.
Pros:
  • Stereo separation is top of the category below $500
  • Bass is tight, quick, and very detailed sounding
  • Easy to install
  • Texture and very resolving
  • Treble is very clean and detailed
  • Superb with jazz and vocals
Cons:
  • Needs a better quality turntable
  • High output version requires 42 to 45dB of gain
  • Bass could be delivered with greater impact
  • Favors jazz, chamber music, and acoustic over rock and pop
Where to buy:
Grado Timbre Sonata3 Phono Cartridge
Grado Labs Timbre Series Sonata3 ($600)
Grado Labs has been designing and manufacturing its award-winning moving iron cartridges in the same Brooklyn facility for more than 40 years, and this family-owned business rarely changes its designs unless the improvements are going to be significant. The Timbre Series Sonata3 moving iron cartridge housed in an Australian Jarrah wood chassis may be one the best from the venerable brand for under $600.
The 4.0mV output makes it compatible with a wide range of phono pre-amplifiers and it’s almost impossible to not pick-up on the Grado house sound; extended dynamics, low end punch, and a warm tonal balance that is highly addictive. The new Timbre models are quieter than the previous models with improved levels of detail. The wood body Grado cartridges sound particularly robust on VPI and Clearaudio turntables.
Pros:
  • High output makes it compatible with most MM phono sections
  • Build quality
  • Adds a layer of warmth and presence to vocals that is highly addictive
  • Far more neutral sounding than previous generation
  • Low end punch
  • Detail retrieval and dynamic punch
Cons:
  • Low level of hum on some Thorens tables with metal platters
  • Requires a better turntable and phono preamplifier to show off its value
  • Not as insightful as some of its rivals
Where to buy:
Dynavector 10x5 MK II Phono Cartridge
Dynavector 10×5 Mk2 ($800)
Dynavector has offered this high output moving coil cartridge (2.5mV) for more than 20 years, and while not inexpensive, the 10×5 Mk2 may be the best overall cartridge of its kind with superb tracking, a balanced presentation, and excellent dynamics making it a great choice for jazz listeners. Installation used to be a tad cumbersome, but that issue has been resolved with some minor changes to the headshell.
The 10×5 Mk2 may not be the “best” at anything, but it has earned its reputation as a workhorse cartridge that manages to survive expensive table and tonearm upgrades. Vocals and brass have impressive presence, and there is a synergy between the 10×5 Mk2 and tube phono pre-amplifiers that makes it a final destination for many.
Pros:
  • Superb tracker
  • Balanced presentation
  • Strong dynamics
  • Presence
  • Works well with a wide range of phono preamplifiers but make sure it has at least 42dB of gain
  • Will last a long time with proper maintenance
Cons:
  • Expensive
  • Can be somewhat tricky to install
  • It’s not the best on this list at anything but consistently good in all areas
  • Needs in the range of 42 to 45dB of gain to match its 2.5mV output
For more information: dynavector.com
Where to buy:
Related reading: Best Budget Phono Cartridges Below $300
23 Comments
23 Comments
  1. Dave E.
    September 20, 2021 at 1:32 pm
    The Dynavector is a good choice for most turntables. I like the Grado “woodie” line better but they really need an arm with a lot of inertia else imperfect records make the arm quiver with audible artifacts. Will likely buy a Hana SH for next cartridge because nude mounted and shibata matters… seen too many solder mounted stylii that just fell out from normal use.
    • Ian White
      September 20, 2021 at 1:40 pm
      Dave,
      I’ve used the Dynavector 10X5 for almost 3 years along with a Denon DL-103 and Hana EL. $750 is my absolute ceiling for cartridges. I really like the Grado Sonata3 but my Thorens tables don’t interact well with it. The platter and cart create a hum that I couldn’t get rid of.
      Hana makes really good carts. Very impressed so far.
      Ian
  2. Lash
    September 20, 2021 at 1:56 pm
    I wonder if the Hana or Grado would be much of an improvement over my Denon 304…
    • Ian White
      September 20, 2021 at 2:03 pm
      Denon stopped making that excellent cartridge which is a pity. I have the new Denon DL-A110 (just the DL-103 in a fancy titanium removable headshell) which I really like but I’m not sure about its $599 asking price.
      The Hana EL is $475 (unless the price changed) and a new Grado Sonata (Timbre Series) is an excellent cartridge depending on the tonearm.
      I really like the Grado carts but I think you need a neutral phono stage with them. They are not as “warm” sounding as they used to be but they have a definite sonic signature. Still made in that skinny townhouse in Brooklyn.
      Ian White
  3. BobPM
    December 6, 2021 at 2:13 pm
    I’m sure there are a million cartridges left off your list, but I believe the real bargain you missed is the AT-OC9XML. Where else can you get into a MC cartridge with a boron cantilever and microline stylus housed in a milled aluminum body for about $549? Purchased one last month for my SL-1200GR, and it sounds quite amazing.
    • Ian White
      December 6, 2021 at 2:25 pm
      Bob,
      Definitely a great cartridge based on what I’ve heard from others. We’ve been adding based on what we get to listen to.
      I’m currently listening to the next generation Grado and Goldring carts and they’re fantastic for the money. The AT is definitely on our radar.
      Ian White
  4. David Crandon
    January 1, 2022 at 4:37 pm
    Why can’t my Shure V15 Type V MR last forever!? Wah, wah, wah….
    • Ian White
      January 1, 2022 at 9:48 pm
      David,
      Jico just introduced a new stylus for it.
      Ian White
  5. Stephen P Fleschler
    February 17, 2022 at 5:15 am
    I would choose the Dynavector first as it will sound great on the most varied LPs. The Denon 103 in a ceramic body is awesome but the standard inexpensive version here is a second choice for vivid presentation. I have a Dynavector 10X2 as a back up cartridge in case of an accident on my main rig (modified SMEIV, modified VPI TNT VI).
    • Ian White
      February 17, 2022 at 11:21 am
      Stephen,
      I use a Dynavector 10×5 on my Thorens and Denon DL-A110 (recent anniversary version of the DL-103) on my vintage Yamaha. Both get the job done.
      Best,
      Ian White
      • Stephen P Fleschler
        August 14, 2023 at 6:57 am
        Ian, great inexpensive choices. After my Benz Ruby3 passed from wear, I replaced it with the Dynavector 20X2L in a $20K analog rig (Zesto Allesso SUT alone is $3600). It makes 90%+ of my 28,500 LPs sound great. Maybe I am missing some resolution, ambiance, etc. that a $4K and up cartridge can provide but three of my friends use the high output version on various VPI tables (sounding great) and one uses a special upgraded and ceramic bodied Denon 103 when he listens to LPs (mostly CDs). I still have the 10X2 as a backup.
  6. Mike Constant
    September 30, 2022 at 1:32 am
    I currently have a Pro-ject Carbon Evo tt with a Sumiko Ranier cart mated to a Denon AVX-2700H receiver. Not overly happy with the sound on my old vinyl. Getting some mixed ideas from Audio Advice. One says to update the stylus to the Moonstone, another says adding a phono pre-amp will give the most noticeable affect, another says upgrade cart to Ortofon 2m Bronze. Thoughts? TIA
    • Ian White
      September 30, 2022 at 10:04 am
      Mike,
      It’s all cumulative. The phono stage in the Denon is the weak link. The 2M Bronze is $400+ upgrade. It’s definitely the best bang for the buck in the 2M range. I’ve used the 2M Black for 4 years and I don’t think it’s twice as good as the Bronze considering the price difference.
      The Sumiko Wellfleet is the same price as the 2M Bronze and just as good.
      An external phono stage will have the biggest impact depending on the rest of the system. It will impact the tonal balance and dynamics for sure.
      Ian White
  7. Andres Hermosilla
    March 9, 2023 at 8:42 pm
    What do you think of the Rega Exact?
    • Ian White
      March 10, 2023 at 12:03 am
      Andres,
      Depends on the table and the rest of the system.
      Anything more you can share?
      Best,
      Ian White
  8. nj
    May 17, 2023 at 11:19 am
    went from a grado sonata to a soundsmith zephyr and feel that despite the large price increase that it was worth every penny. it is mounted on a vpi classic tt and running through a rogue sphinx, and I’ve never enjoyed my system and music collection more than I do now.
    • Ian White
      May 17, 2023 at 3:43 pm
      NJ,
      Peter makes amazing cartridges. The Zephyr II is a wonderful cartridge. I’ve heard a number of them on the Classic 3, Direct Drive, and even an older HW-19 MKIV and they were all superb cartridges. Enjoy your music. And don’t upgrade!
      Best,
      Ian White
  9. ORT
    August 5, 2023 at 10:35 pm
    I have a Sumiko Moonstone installed in my favorite ‘table my X2 or is it 2X Pro-Ject with the SB and humongous acrylic platter!!
    Hah! Take that, Will McCormick! I am one of the cool kids now so you can take an airborne intercourse back to the House at Poop Corner, Piglet.
    ORT
  10. TonyE
    August 13, 2023 at 6:44 am
    I had a Sonata (low output) for years… but I upgraded to the Master 2 (low output) and it was money well worth it.
    Particularly as Grado gives you a healthy trade in chunk as you move up the line.
    My TT is a Linn LP12 with the Ittok LVII tonearm, Lingo/Karousel/etc.. and my preamp is a DIY fully adjustable job (resistive load, inductive load, gain) based on the Pass Pearl 2.
    Note: the Grados want a 47K load impedance and don’t care much about the inductance (moving iron design). So, if you get a low output version (currently 1mV) you need a “sort of” hybrid preamp… high gain (as for MC) but 47K load (as for MM).
    Also, you didn’t mention the cartridge set up which requires much more than just tracking weight and anti skating… you also have to set up its azimuth, rake, VTA, etc… the wooden Grados are hard to set up because the stylus is set back in the body and are hard to see from the front.
    The step up transformer is pretty much no longer needed… just get a phono preamp with settings for MC and spend the money on a better TT/tonearm/cartridge/preamp.
    Oh, BTW, what’s with that note: “Only 50% of vinyl buyers own a turntable”? What’s the point of buying records if you can’t play them?
  11. N J Flanigan
    August 22, 2023 at 2:51 pm
    absolutely love my soundsmith zephyr, well worth the upgrade cost from my sonata 3
    • Ian White
      August 22, 2023 at 3:26 pm
      NJ,
      Peter makes amazing cartridges. Not even a question. When I can get a more current review sample, it will likely make this list.
      Best,
      Ian White
  12. Ed Brumbaugh
    August 6, 2024 at 4:09 pm
    Good article, thanks. I upgraded my entry level Audio-Technica turntables $69.00 cartridge with an Audio-Technica AT-VM95ML dual moving magnet phono cartridge … made a big difference. I feel like regardless of your turntable, it’ll only be as good as the cartridge you’re using, in my case, the $500.00 turntable came equipped with a $69.00 cartridge, so I felt like I could get more performance out of upgrading the cartridge, nothing too extreme in the upgrade to the 95ML, but it was definitely a upgrade I’d recommend to folks. Thanks again.
    • Ian White
      August 12, 2024 at 1:31 pm
      Ed,
      Thank you for reading it. I tend to lean in the other direction when it comes to tables and cartridges. My advice to consumers is spend more on the table and see how it responds to different cartridges that might not be super expensive.
      I have had good luck with cartridges like the Denon DL-103, Goldring E4, Sumiko Blue Point No.3 on tables that are 3 to 5 times the price of the cartridge. A better table provides a long-term platform that can only get better as you upgrade the cart and phono stage.
      But I do like the AT-VM95ML very much. Good choice!
      Best,
      Ian White
Turntables, Phono Cartridges and Tonearms
From $6,000, the Pro-Ject Classic Reference turntable combines a vintage look with high-end construction and performance for audiophiles.
At $2,495, the Grado Signature HP100 SE are the company's new flagship open-back headphone that are hand-assembled in Brooklyn with newly engineered drivers, detachable...
Does it make sense to buy a vintage turntable? We explain why, what to look for and what to be aware of.
The backbone of a home theater or surround sound system, today's best AVRs are packed with features and performance (updated for 2024)
Denon's budget friendly Dolby Atmos AV receiver offers excellent connectivity and sound quality for under $600.
Ask an Expert
The ultimate guide to choosing a SVS subwoofer for home theater or high fidelity music listening? All 16 models compared!
JBL recently released an updated version of its classic speaker with entirely new components and an updated internal design. Can the copy beat the...
At $795, the Rega Nd7 is the world's first phono cartridge to use ultra-high powered Neodymium magnets in a moving magnet design.
