Best Bookshelf Speakers: 2022 Buying Guide
The definitive buying guide to the best bookshelf speakers from $300 to $1,400. Our picks from the best high-end brands.
Focal Chora 806 Bookshelf Speakers Colors
Most people love the idea of a pair of floor standing loudspeakers in their living room or den, but domestic concerns often put a serious dent in that plan. There’s also the issue of cost; consumers don’t necessarily want to spend thousands of dollars on speakers and the truth is that the quality of bookshelf or stand-mounted loudspeakers in 2021 has never been better.
The idea that you have to accept mediocre sound quality if you can only afford to spend $500 for a pair of speakers is completely false. Let’s put that nonsense to bed.
Getting more for less now means that you can spend more on a better amplifier or network streamer or turntable to go along with your new loudspeakers. Building a great sounding hi-fi system on a budget below $3,000 is actually the new normal and don’t let anyone shame you into thinking you’re not an audiophile if that’s where you need to start.
Paradigm Monitor SE Atom ($318/pair)
Paradigm Monitor SE Atom Bookshelf Speaker in Black
Never judge a pair of speakers by its grille covers or its price. The Paradigm Monitor SE Atom will not impress with their boxy and somewhat austere appearance – and that’s exactly why you need to give these overachieving two-way bookshelf loudspeakers a serious listen. Where the rubber meets the road with these loudspeakers is when you remove the grille covers and discover that Paradigm is spoiling you with a scaled-down version of their X-Pal perforated phase-aligned tweeter and a robust 5 ½” mid-bass driver that belongs on loudspeakers that are double the price. The Monitor SE Atom are relatively easy to drive but take a significant step forward if you reward them with power. Tubes or warm sounding solid-state is the way to go if you want to hear what these loudspeakers can do. $318/pair at Amazon.
Q Acoustics 3030i ($399/pair)
Q Acoustics 3030i Bookshelf Speaker in Walnut
The updated 3030i is larger than its predecessor, featuring a new crossover, reinforced internal bracing, as well as recessed binding posts for those who may want to wall-mount or set-up close to the wall. Q Acoustics have gone the extra mile with the finish options as well; the English Walnut, Graphite Grey and Arctic White give the 3030i a modern look that belies its price. The 3030i are not particularly difficult to drive but they benefit from some power; its 6.5” mid/bass driver is capable of excellent bass extension with the right amplifier. The 1” soft-dome tweeter (taken from the more expensive 3050i) balances out the warm tonal balance, and slightly recessed presentation of the speaker with some needed bite. Pair these up with an integrated amplifier from NAD or Cambridge Audio and you’ll be in sonic heaven.  $399/pair at Amazon.
Read our Q Acoustics 3030i Review.
Get system recommendations in our Q Acoustics 3030i: Audiophile System Builder.
PSB Alpha P5 ($399/pair)
PSB Alpha P5 Bookshelf Speaker in Walnut
For almost forty years, Paul Barton has been engineering high-performance loudspeakers with a focus on value/performance. The Alpha P5 are small two-way bookshelf loudspeakers at a price point with a lot of competition – a scenario that makes it hard for products to differentiate themselves enough to be considered category leaders. Make no mistake, the Alpha P5 are remarkable loudspeakers with even modest amplification, but they blow past anything in their price range with a better amplifier with wonderful resolution, tonal accuracy, and a very dynamic presentation that makes them a solid long-term purchase for anyone who loves music. $399/pair at Amazon.
See our PSB Alpha P5 review.
Wharfedale Diamond 12.1 ($399.00/pair)
Wharfedale Diamond 12.1 Bookshelf Loudspeaker in light oak
The Wharfedale Diamond 12.1’s are the ideal size for a desktop loudspeaker or placement on a credenza in a home office scenario. These stand-mounters are a two-way, bass-reflex design. The 5-inch mid/bass driver uses a polypropylene/mica composite cone material, and the tweeter is a 1-inch textile dome design that offers a very smooth sounding top end and excellent dispersion. Coherency and detail are both excellent, and we were pleased to hear that they don’t make excuses for poor recordings. Feed them garbage and you’ll know it. Bass response is surprisingly robust to a point; hence the reason why I’m suggesting a subwoofer in this scenario. The Wharfedale Diamond 12.1’s can deliver a punch – just not a knock-out blow. They work amazingly well with the NAD C316BEE V2 integrated amplifier. $399/pair at Amazon
See our Wharfedale Diamond 12.1 review.
Get system recommendations in our Wharfedale Diamond 12.1 Audiophile System Builder.
KEF Q350 ($699.99/pair)
KEF Q350 Bookshelf Speaker in Walnut
The KEF Q350 bookshelf loudspeaker looks and sounds very little like its predecessor; thanks to the next generation of its Uni-Q driver technology with its tangerine waveguide on the tweeter which helps the concentric driver direct sound more evenly. The sleek minimalist design dispenses with everything but a clean looking baffle and is only available in either satin white or black. The Q350 are rear ported and require some space between them and the wall to retain their open presentation, while benefiting from boundary reinforcement. They are slightly more reserved sounding than some of their competitors, but they reproduce music with a greater sense of scale and coherency that is hard to resist. $699/pair at Amazon.
Klipsch RP-600M ($729/pair)
Klipsch RP-600M Bookshelf Speaker in Walnut
The RP-600M have been a huge success story for Klipsch and helped renew interest in their more expensive Heritage-series loudspeakers at the same time. Despite their reputation for being forward/bright sounding, the RP-600M’s 1-inch titanium-dome tweeter with hybrid cross-section Tractrix horn never crosses a line that makes them sound etched or bright. Horns have ample detail, and it is their overall presence and strong dynamic capabilities that makes these speakers such an engaging listen. The RP-600M are a large set of bookshelf loudspeakers that require proper stands. While not bass monsters, the RP-600M are incredibly easy to drive and benefit from warmer sounding amplifiers. Was $729/pair. Check pricing at Amazon, Crutchfield or Klipsch.com.
See our Klipsch RP-600M review.
Get system recommendations in our RP-600M Audiophile System Builder.
Bowers & Wilkins 606 S2 Anniversary Edition ($899.99/pair)
Bowers & Wilkins 606 S2 Anniversary Edition Bookshelf Speaker in Matte Black
B&W prolonged the lifespan of the award-winning 685 S2 bookshelf loudspeakers before introducing the 606, but the wait was certainly worth it. A truly engaging pair of loudspeakers designed for both stand or media console placement, the 606 deliver a taste of B&W’s more expensive Continuum cone technology which is usually reserved for its more expensive models. Its 6.5” midrange/bass driver can deliver deep, tight bass that is well balanced against the rest of the sonic spectrum. The lively sounding tweeter will never fail to retain your attention, but don’t get the impression that these loudspeakers are bright sounding. They are engaging and very balanced sounding.
$899.99/pair at AudioAdvice.com and bowerswilkins.com.
Sonus faber Lumina I ($900.00/pair)
Pair of Sonus Faber Lumina I Bookshelf Speakers Walnut
Sonus faber has been manufacturing loudspeakers in Italy for almost four decades (2023 will be its 40th anniversary), and the luxury brand started by the late-Franco Serblin has preserved its reputation for manufacturing the world’s most beautiful loudspeakers with great skill. Sonus faber’s loudspeakers are aspirational products for many audiophiles for both their visual appeal and acoustic capabilities. The Sonus faber Lumina 1 continue that tradition at a much more affordable price.
One of the most unique design aspects of early Sonus faber designs was the use of leather on the front baffle; a detail the Lumina I forgo for a leather-wrapped enclosure instead that looks especially striking with the Wenge-finished (real wood veneer) multilayer front baffle. The Lumina collection are available in Walnut, Piano Black, and Wenge – the magnetic grille covers should be left in the box for both sonic and aesthetic reasons. There are two sets of binding posts on the rear panel for bi-wiring or bi-amping.
Read our Sonus faber Lumina I Review.
Get system suggestions in our Lumina I Audiophile System Builder.
Focal Chora 806 ($990/pair)
Focal Chora 806 Bookshelf Speaker in Darkwood
The Chora 806 are part of larger group of affordable loudspeakers from Focal that have instant appeal; they are well made, modern and clean looking, and the sound quality is excellent for the asking price. The Chora 806 are front-ported two-way bookshelf speakers that can be set-up close to the wall on a media unit or credenza if that reality applies to you and your room. The Chora 806 offers a really pleasant balance in the upper frequencies and I doubt too many will find the loudspeaker to be hyperdetailed or bright sounding at all. You get all of the extension and detail that you need and nothing more. $990 at Crutchfield.
See our Focal Chora 806 review.
Wharfedale EVO4.2 ($999.99/pair)
Wharfedale EVO4.2 Bookshelf Speaker in Black
The first things you notice about the affordable EVO4.2 are their size and weight; very few bookshelf speakers are 30 pounds and 18” tall. The robustness of their construction translates to their sound quality as well. Wharfedale has built a full-range sounding loudspeaker with layers of resolution, a laid-back sounding presentation that makes it compatible with a wider range of equipment, and an exceptionally airy sounding top end that you rarely find in loudspeakers below $2,000. The overall coherency and midrange transparency make the EVO4.2 one of the best sounding and affordable bookshelf speakers you can find. The one caveat would be the need for heavy-duty loudspeaker stands between 18”-22” to place the tweeter at the right listening height. $999.99 at Crutchfield.
Polk Audio Legend L100 ($999.99/pair)
Polk Audio Legend L100 Bookshelf Speaker
Polk Audio have been manufacturing loudspeakers for over 40 years, and the L100 might be one of their crown achievements. Unless your listening room is cavernous, the L100 might be one of the best sounding full-range bookshelf speakers we have come across in many years; they do require a lot of power to show off their capabilities and we would suggest 75-100 watts of power (not A/V receiver watts) as the bare minimum. The L100 utilize Polk’s 1” ring radiator tweeter, and 5 ¼” turbine cone midrange/bass driver with great sonic results. This is a bold and accurate sounding loudspeaker with a warm midrange and a lot of detail. $999.99/pair at Crutchfield.
See our Polk Audio Legend L100 Review.
Learn what components pair well in our Polk L100 Audiophile System Builder.
ELAC Carina BS243.4 ($1,379.98/pair)
ELAC Carina BS243.4 Bookshelf Speaker in White
ELAC’s Andrew Jones has a remarkable track record of designing both price-no-object and entry-level bookshelf speakers that deliver the sonic goods. It is his affordable offerings, however, that continue to inspire delivering sound quality that few designers have proven capable of squeezing out of two-way bookshelf designs priced below $1,500. The Carina BS243.4 raise the bar with its JET folded ribbon tweeter, and 5 ¼” aluminum cone mid/bass driver that can energize a room and create an enormous sounding soundstage when set-up properly. The Carina can sound a tad dry with the wrong amplification; tubes are a great option with these sleek looking loudspeakers which do require some power to open up. $1,379.98 at Amazon.com.
13 Comments
13 Comments
  1. James F Tremblay
    March 29, 2021 at 10:36 pm
    A fine smattering of speakers. The 3030’s I have, but the EV04.4’s are on order.
  2. MrSatyre
    March 30, 2021 at 2:02 am
    “Bookshelf” is starting to become a misnomer. As everyone here knows, many of these would not fit on a bookshelf or work up against the back of a bookcase. These need to be on stands. Let’s call them what they are: stand-mount speakers.
    • Ian White
      March 30, 2021 at 10:28 am
      I agree. Especially because more and more manufacturers are making them larger and too deep to fit.
    • Vlada
      November 28, 2021 at 9:56 am
      I agree with you, but there’s a question would you really want them inside a bookshelf?
      I have my QA 3020i in a bookshelf (wife acceptance factor…) and lows are a bit augmented, while highs are recessed. None of that when they are on stands. I can’t really think of any “bookshelf” speakers that can be placed in an actual bookshelf and sound right.
      • Ian White
        November 28, 2021 at 12:58 pm
        I think there are some “bookshelf” loudspeakers that are sealed cabinets or front-ported that can work.
        The Q Acoustics 3030i/3020i have unusual dimensions and are not really designed for bookshelves. I use a pair of IsoAcoustic stands for the 3030i on a dresser and they lose some of their low-end impact but sound dramatically more open.
        Ian White
        • MrBond
          March 10, 2022 at 1:50 pm
          I agree that bookshelf speaker has become a bit of a misnomer. However, I would like to point out that Andrew Jones completely redid the original Debut bookshelf speakers so that they are now front-ported and work much better on an actual bookshelf. So it appears that Andrew Jones still cares.
          • Ian White
            March 10, 2022 at 3:14 pm
            Andrew is a great designer and person. He’s done the industry a major solid with his work at ELAC. Curious to see where he lands.
            Ian White
  3. JD
    November 29, 2021 at 12:09 am
    Appreciate the great info, Ian. I am looking for a pair of bookshelf speakers that will double-duty as L/R in a HT setup as well as stereo music listening. Due to room setup and girlfriend input :), I need to go front-ported so wanted to check whether the Focal is the only front-ported on this list? Since I started my search, I’ve realized how limited the front-ported options are…maybe a few ELAC models are my current choice so just seeing what else may be out there. Thanks!
    • Ian White
      November 29, 2021 at 12:42 am
      JD,
      Thank you for taking the time to read it.
      I have similar issues with Mrs. White in the living room (that sounded wrong) and I also require front-ported as well.
      Options:
      Focal Chora 806 (I’ve never heard their center channel speakers in this category if you need one in this setup)
      Wharfedale EVO Series (they use a bottom port)
      ELAC Debut Reference DBR62
      Spendor Classic Series are front-ported but much more expensive.
      Hope this helps.
      Ian
      • JD
        November 29, 2021 at 1:57 am
        Thanks for the prompt response and classic boardgame reference LOL
        No center channel needed at the moment as going to attempt going without for HT to see how that goes.
        I was not aware about the porting on the Wharfdale model so that’s great news and I’ll defo check them out as well as Sonus Faber Lumina 2’s that I recently heard while doing an amplifier demo and really liked.
        Other than fitting on a bookshelf without a ton of space behind them, the only GF criteria was an option for a white color which I think the ELAC and Wharfdale both can meet but I may have to test out my negotiation skills if I like the SF more (and it’s not rear-ported)…
        Also, thanks for the Spendor recommendation as they seem like a potential upgrade option if I win the lottery 🙂
        Thank you again and happy holidays!
        • Ian White
          November 29, 2021 at 2:30 am
          JD,
          The white looks really nice on the EVO Series.
          The Wharfedale EVO sound better on stands as a heads up. You might need some room behind them for cables. Tight in close with thicker wires. Definitely use banana plugs.
          I’ve reviewed the Lumina I and really liked them. They don’t have the bass impact of the EVO or ELAC, if you’re looking for a bookshelf speaker with some low end punch.
          Ian
  4. james
    January 24, 2022 at 7:16 pm
    I just completed a pretty exhaustive “audition” of a number of speakers in the sub $600 range to pair with my new desktop stack. It included the PSB Alpha 5 (runner up) and the Wharfedale Diamond 12.1 from your list. Others were ELAC Debut 2.0 B5.2, Jamo S 803 (which did amazingly well consider how cheap they are), KEF Q150, JBL Stage A130 and Airmotiv B1+.
    The winner was the Dali Spektor 2. I did pair them all up with my subwoofer (again, not looking to spend a fortune), Definitive Technology ProSub 800.
    Without the sub the Alpha 5s would have been the victor.
    I am intrigued by the 3030i and Paradigm since I have a few weeks left to return the Dali’s if someone can knock them off 🙂
    • Ian White
      January 24, 2022 at 11:09 pm
      I use the 3030i in my bedroom system.
      Probably too large for the desktop. The depth requires some room. They also need more power than less — something I’ve discovered over the past year.
      Dali makes really underrated speakers.
      Ian White
March has been a busy month for new headphone introductions, including the Focal Bathys MG and Meze Audio POET.
The traveling headphone show, CanJam came to New York City last month and we were there. Here are a few highlights.
The award-winning Focal Bathys wireless noise cancelling headphones arrive in a new black color option for $699, the same price as before.
Larger cabinet, bi-wiring, new crossover, and reengineered bass port are only some of the changes for the new Triangle BOREA BR04 which will retail...
Focal extends its wired headphone range with two affordable models based on the Bathys architecture in open and closed-back configurations.
Before you get too excited, British audiophiles are getting a much better deal on these Heritage Series Limited Edition loudspeakers.
