VIZIO XVT553SV, XVT473SV, XVT423SV TruLED LCD HDTVs
VIZIO XVT473SV TruLED LCD HDTV
Features Full Array TruLED LCD technology for significant performance advantages over competitors' sets, with superior uniformity, better off-angle viewing and deeper blacks
VIZIO today announced a new lineup of XVT (Xtreme VIZIO Technology) Series HDTVs featuring Full Array TruLED LCD HDTV technology including the 42-inch XVT423SV, 47-inch XVT473SV and 55-inch XVT553SV models.
With added zones of Smart Dimming, unmatched 10,000,000:1 contrast ratios and 240Hz SPS (scenes per second) refresh rates, the new models outperform competitive HDTVs that use Edge Lit LED technology.
All of these new XVT televisions feature a sleek and slimmer new profile. Depths have been reduced from 5-inches to less than 3-inches.
Full Array TruLED technology
As other leading HDTV makers have elected to use Edge Lit technology, even in their most expensive models, VIZIO remains firmly committed to performance through the use of Full Array TruLED technology with Smart Dimming to deliver superior picture quality. Edge Lit designs exhibit variations in both light and dark from screen edge to center. TruLED designs present uniform brightness across the entire screen area. TruLED sets also provide much better off angle viewing and vastly superior black reproduction.
Smart Dimming
VIZIO's new Full Array TruLED sets feature additional zones of Smart Dimming, which improve performance and provide the highest contrast ratios yet. Additional zones of Smart Dimming allows for the ability to turn off individual zones of LEDs for the absolute blackest blacks. The 55″ XVT553SV and 42″ XVT423SV models have 120 zones, compared to 80 zones in their predecessor models, and the 47″ XVT473SV model steps up to 160 zones from 120 zones. These sets reach a 10,000,000:1 contrast ratio, a major improvement over the previous generation XVT series, which had a 2,000,000:1 contrast ratio. Additionally, VIZIO's 240 Hz SPS (Scenes per second) Smooth Motion technology provides sharp, blur-free images with less judder, even in fast action scenes.
VIZIO Internet Apps
VIZIO XVT473SV Inputs
Each of these VIZIO XVT series HDTVs brings the best of the web to the home through VIZIO Internet Applications, the industry leader with over 75,000 movie and TV show options and 10 Million songs. Unlike competitive sets that require the purchase of external adaptors, VIZIO provides seamless state-of-the-art wireless Internet access through integral Dual Band 802.11n Wi-Fi. The user experience is vastly improved through the industry's only remote control with dual Bluetooth/Infrared functionality and a slide-out QWERTY keyboard.
Class-leading Sound Experience
High definition audio is an important element in each XVT Series set, enabled through the use of quality speakers and SRS TruSurround HD premium audio processing, which creates an immersive virtual surround sound from stereo and surround sources. In addition, SRS TruVolume eliminates sharp jumps in volume that may be heard when switching from channel to channel or coming in and out of commercial breaks.
All the Right Connections
Providing great flexibility for multiple sources including disc players, portable devices and gaming, the 55″ XVT553SV, 47″ XVT473SV and 42″ XVT423SV have 5 HDMI 1.3 inputs. All sets are available and shipping now.
VIZIO XVT Series
Model Size/
Res.
Contrast Ratio Smooth Motion Smart Dimming HDMI 1.3 Inputs Dual Band 802.11n VIZIO Internet Apps Bluetooth Remote SRS Audio MSRP
XVT553SV TruLED 55″ FHD 10M:1 240 Hz SPS 120 Zones 5 Yes Yes Yes Yes $2,199
XVT473SV TruLED 47″ FHD 10M:1 240 Hz SPS 160 Zones 5 Yes Yes Yes Yes $1,799
XVT423SV TruLED 42″ FHD 10M:1 240 Hz SPS 120 Zones 5 Yes Yes Yes Yes $1,199
XVT373SV Razor LED 37″ FHD 1M: 1 120 Hz Yes 4 Yes Yes Yes Yes $899
XVT323SV Razor LED 32″ FHD 1M: 1 120 Hz Yes 4 Yes Yes Yes Yes $699
“Each of our XVT TruLED sets uses a Full Array with local dimming that produces an unquestioned superior picture. Many competitive manufacturers have decided to use only Edge Lit technology in their flagship products, but edge lighting results in an inevitable compromise in performance.”
— John Schindler, VIZIO VP New Products
Vincent Audio SV-500 MK Hybrid Integrated Amplifier
SV-500 MK Adds HDMI ARC and Bluetooth 5.0 Connectivity and outputs 50 watts per channel for $1,500.
Fell Audio Amp and Disc Fell Audio Amp and Disc
Fell Audio aims to attract British hi-fi buyers seeking retro aesthetics with value driven audio performance from its inaugural £1000 stack.
Schiit Audio Wotan Stereo Power Amplifier Front Angle Silver Schiit Audio Wotan Stereo Power Amplifier Front Angle Silver
Lots of power, practical integration and control, and a reasonable price tag make the Wotan power amp worth consideration, especially if you own other...
Fezz Audio Equinox Vacuum Tube DAC in Sunlight Finish Front View Angle Fezz Audio Equinox Vacuum Tube DAC in Sunlight Finish Front View Angle
Starting at $2,995, the Fezz Audio Equinox Vacuum Tube DAC is the most affordable D/A converter with Lampizator technology.
iFi GO link Max Dongle DAC connected to laptop and IEM iFi GO link Max Dongle DAC connected to laptop and IEM
Dongle DACs
With more power and balanced connectivity, the iFI GO link Max dongle dac is a great upgrade over the previous GO link and only...
Audio CU Sound Over Power Audio CU Sound Over Power
A/V Furniture & Accessories
AUDIO Cu plug-in adapters eliminate long cable runs by sending up to 10 channels of audio over power lines already in your home.
dts-holiday-guide
Treat the audio enthusiast in your life to the best DTS-powered products this holiday season.
Daily Deals
Our favorite soundbars on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
In addition to its TVs, Vizio also makes an extremely popular line of soundbars. The M-Series has been updated for 2023.
The Vizio M51ax-J6 5.1-channel Sound Bar includes external surround speakers, support for Dolby Atmos, DTS:X and more for only $329.
For 2024 VIZIO is introducing seven new soundbars priced from $99 to $499 that easily attach to the bottom of a TV.
HDTV 4K & 8K TV
At 86-inches in diagonal, Vizio's largest 4K TV ever arrives at the end of April for only $999.
HDTV 4K & 8K TV
Walmart has acquired Vizio and that could be good news for consumers looking to get a good price on a new TV.
HDTV 4K & 8K TV
Vizio simplifies its 2023 4K QLED TV line-up down to 5 new models, priced from $399 to $999 in 55, 65 and 75-inch screen...
HDTV 4K & 8K TV
Vizio's new TV Home Screen provides easier navigation, enhanced features, and fixes a number of issues that plagued SmartCast.
