Laser Printers
Samsung CLP-325W and CLX-3185FW Wireless Laser Printers
Samsung announced its latest wireless printers for personal, home office and small business users. The Samsung CLP-325W and multifunction CLX-3185FW deliver high quality prints using Samsung's new Polymerized Chemical Toner, and have the small footprint and simple functionality that make them a fit for a variety of home and small office users.
High Quality Prints
The Samsung CLP-325W and CLX-3185FW feature Samsung's new advanced Polymerized Chemical Toner, which creates high-resolution, high-gloss prints. In addition, the toner creates more durable prints thanks to the chemical toner fusing ability. By having stronger fusing, the print is preserved with less image destruction.
These printers also consume less energy. To do so, the high transfer efficiency of the printers create a thin and uniform toner layer, which allows the printers to create less waste toner and to use a lower fusing temperature. The toner also uses up to 35% less electricity compared to manufacturing conventional toner, which results in a significant reduction in carbon dioxide.
In addition, both printers have printer speeds of up to 17 pages per minute (ppm) in the monochrome setting and 4 ppm in the color setting. Users have the choice between a 1K and 1.5K toner yield.
Space-saving Design and Easy to Use Features
Designed to fit small workspaces, both the CLP-325W and CLX-3185FW have ultra compact footprints (CLP-325W – 15.3″x12.3″x9.6″; CLX-3185FW – 16.4″x14.9″13.5″). Available in Samsung's signature black finish, the printers have a stylish exterior design that naturally blends with Samsung's other office products, including monitors and laptops.
Samsung CLX-3185FW Printer
Both printers feature the one-touch Wi-Fi Protected Setup (WPS) button to ensure setting up a wireless connection is quick, easy and secure. After selecting the WPS button on the router and on the printer, the CLP-325W and CLX-3185FW will automatically connect to the user's wireless network in less than two minutes.
Both units also are compatible with Samsung's AnyWeb Print software, which enables users to print just the information they need. Using this software, users can select, drag and drop contents of interest from various Web pages onto a blank page which can then be saved or printed.
As a multifunction printer the CLX-3185FW is able to copy, scan, fax and print. This model also includes a LCD control panel and easy-to-use blue compass navigational system which allows customers to easily browse through multifunction options.
Price and Availability
The CLP-325W ($199.99) and CLX-3185FW ($399.99) will be widely available in mid-January 2011.
Sennheiser HD 550 Headphones
Gaming is driving the headphone market and Sennheiser's new HD 550 might be a fantastic option below $300 for audiophiles and gamers.
JBL Synthesis SMA-8300 and SMA-4750 Stacked JBL Synthesis SMA-8300 and SMA-4750 Stacked
Lots of power, bridgeable configuration options, and rack-compatible sizes add flexibility to any custom home theater setup.
Rega Brio MK7 Integrated Amplifier Rega Brio MK7 Integrated Amplifier
Rega's forthcoming Brio MK7 Integrated Amplifier will be available this month and is creating a stir with its internal DAC for only $1095.
Pro-Ject AC/DC Turntable Top View Pro-Ject AC/DC Turntable Top View
Pro-Ject's Artist Series of turntables has expanded with a new offering paying homage to the legendary band from down under. The price might leave...
WiiM Vibelink Amp WiiM Vibelink Amp
The WiiM Vibelink drops streaming, but users gain an inexpensive, flexible, and powerful integrated amplifier.
Man wearing Focal Bathys Black Edition Wireless Headphones Man wearing Focal Bathys Black Edition Wireless Headphones
The award-winning Focal Bathys wireless noise cancelling headphones arrive in a new black color option for $699, the same price as before.
