Polk Audio Command Bar is Alexa Enabled Soundbar
Polk Audio Command Bar - Alexa soundbar
Amazon Alexa Enabled Sound Bar with Wireless Subwoofer and Remote Control
At CES 2018, Polk Audio introduced Command Bar, a voice-controlled sound bar with the Amazon Alexa Voice Service built in. It’s due out spring 2018 for $299.95 and includes a wireless subwoofer, remote control and is 4K HDR compliant.
When you say “Alexa”, the Command Bar automatically lowers its volume letting you clearly state your command. That’s because Amazon Alexa Voice Services and far-field microphones are built-in to the soundbar. And that’s the difference between “Alexa Enabled” vs. “Works With Alexa.”
Voice commands can set master volume, mute, bass, sound modes, and source selection through the Polk Connect Skill, or control connected smart home devices. When audio is playing at the loudest levels, owners can use the speak button in the remote control to lower playback volume and make it easier for Alexa to hear voice commands.
On the back, Polk Command Bar includes a dedicated HDMI port designed to fit Amazon Fire TV devices and other HDMI streaming players with wide form factors. A built-in USB port in the rear panel makes it even more convenient to install USB-powered streaming devices, like Fire TV.
The Polk Command Bar supports a full set of smart home skills to control lights, locks, and HVAC in addition to a variety of Amazon Alexa-supported music services, including Amazon Music, and can even read books from Audible. Support for additional music services will be announced later in 2018.
Polk Command Bar integrate two 1.25 x 3.25-inch full-range drivers, two 1-inch tweeters and a ported, wireless 6.5-inch subwoofer for big, dynamic sound. The sound bar is compatible with 4K HDTVs and HDR via dual HDMI 2.0b inputs. Support for Dolby and DTS surround formats provides customers with an immersive room-filling home theater experience.
Features:
  • Amazon Fire TV Compatible—An extra HDMI port is custom designed to fit Fire TV devices and other wide HDMI streaming devices. A built-in USB port can also power compatible Fire TV devices.
  • Amazon Alexa Voice Control—At launch, customers will be able to simply ask Alexa to play music, control smart home devices, provide information, read the news, set alarms, read audiobooks from Audible, control Amazon Video on Fire TV, and more. The Polk Command Bar also features Universal control via HDMI CEC, IR Remote and Alexa voice commands. Alexa is always getting smarter and the Polk Command Bar receives automated over-the-air updates to provide customers access to new services and features.
  • Connectivity— Supports Wi-Fi-and Bluetooth along with a full suite of wired inputs, two built-in 4K HDMI 2.0b inputs (Dolby Vision, HDR10 and HDCP 2.2 compliant), one HDMI (ARC) output and optical input for TV audio. It also ships with both HDMI and optical cables.
  • Polk Voice Adjust for Crystal Clear Dialogue—Polk’s proprietary dialogue-enhancing technology, VoiceAdjust, allows consumers to isolate and adjust the voice channel for clear, crisp vocals.
  • 4K TV Compatible—Works with 4K and HDTVs—plus, built-in dual HDMI 2.0b inputs ensure 4K HDR content looks great.
  • Polk Smart Remote Compatibility: Whether connecting via Optical or HDMI cable, Polk Command Bar features built-in support for popular IR TV remotes from Samsung, LG, Sony, and Vizio. It is also compatible with most CEC-enabled TVs.
  • Optimized Sound Modes—The Polk Command Bar is outfitted with several preset sound modes for Night, Movies, Music, and Sports, which optimize the sound bar and subwoofer levels to ensure owners get the clearest dialogue, big room-filling sound and deep bass.
  • Simple Mounting—Designed for both tabletop and wall-mounting with built-in keyholes slots for easy mounting.
Pricing and Availability
Polk Audio’s Command Bar will be available in the U.S. and Canada in the spring 2018 and will retail in the U.S. for $299.95. Preorders start April 1, 2018 at Amazon.com. It will be available in the UK, Germany, Australia and more regions later in 2018.
New Klipsch Klipschorn Speakers 2025 Lifestyle
With improved drivers and the addition of an active crossover option, the Klipschorn AK7 and La Scala AL6 are ready to take on all...
iFi iDSD Valkyrie Portable DAC Amplifier iFi iDSD Valkyrie Portable DAC Amplifier
K2HD Technology, DSD Remastering, 5,700mW peak output, lossless Bluetooth, and 18-hour battery life are just some of the features of the iFi iDSD Valkyrie.
UberLight Frame LED Light Lifestyle UberLight Frame LED Light Lifestyle
With 500 lumens of LED lighting across a slim beam, no dust or dirt on your vinyl records can hide from the UberLight Frame.
Audiolab 6000A MKII Integrated Amplifier Lifestyle Black Audiolab 6000A MKII Integrated Amplifier Lifestyle Black
After 7 years, Audiolab has replaced the classic 6000A with the MkII iteration. New toroidal output transformer, 32-bit ES9038Q2M ESS Sabre chip, and HDMI...
Sennheiser HD 550 Headphones Sennheiser HD 550 Headphones
Gaming is driving the headphone market and Sennheiser's new HD 550 might be a fantastic option below $300 for audiophiles and gamers.
JBL Synthesis SMA-8300 and SMA-4750 Stacked JBL Synthesis SMA-8300 and SMA-4750 Stacked
Lots of power, bridgeable configuration options, and rack-compatible sizes add flexibility to any custom home theater setup.
New Polk Audio Reserve Series loudspeakers are aimed at the next generation of audiophiles looking for affordable high-end sound.
Looking for an affordable subwoofer this holiday season? The Polk Audio Monitor XT10 retails for $299.
Podcasts
A/V Industry veteran, Philip Jones of Sound United and co-owner of ProjectorReviews.com shares his passion for hi-fi and home theater, along with some interesting...
Loudspeakers
We are very sad to report the passing of Al Ballard, longtime Polk Audio VP of Marketing and industry marketing icon.
What you need to know about understanding frequency response curves of loudspeakers.
Daily Deals
The Polk Audio Labor Day Sale in on! Save up to $1,000 on Polk Reserve and Legend Series loudspeakers which is a huge savings.
The Polk Audio MagniFi Mini AX packs in features and big sound in a very small package. We think it's better suited for a...
Get big sound for your TV viewing with a soundbar that is only 14.5-inches wide! Find out how Polk Audio MagniFi Mini AX makes...
