Car Amplifiers
Pioneer GM-D9601, GM-D8601 and GM-D8604 Car Amplifiers
GM-D9601
Pioneer announced its new line of high-efficiency “GM Digital” series Class-D automotive amplifiers, consisting of the GM-D8604 4-channel model and GM-D9601 (pictured) and GM-D8601 mono models. Pioneer’s digital amplifiers can produce the same power output as conventional amplifiers more than twice their physical size through improvements in their Class-D amplifier technology and design. The new amplifiers feature an extremely compact chassis for maximum installation flexibility, a new industrial cosmetic design, balanced audio inputs for improved sound quality and higher power output compared with previous models.
Power and Performance
The GM-D9601 and GM-D8601 mono amplifiers are designed specifically to power large subwoofers that can produce low bass frequencies that are often missing in most vehicles. Both models feature 1-ohm stability, allowing them to deliver extreme power and high current in a wide variety of connectivity configurations, from a single subwoofer to multiple subwoofer applications. The larger GM-D9601 can deliver up to 1200 Watts (1-ohm) of RMS power while the GM-D8601 produces up to 800 Watts (1-ohm) of RMS power. Both units feature selectable bass boost at 0dB, 6dB, or 12dB at 50Hz.
“The new GM-D amps can produce more power in the same size footprint as last year’s models while maintaining the same great sound quality,” said Ted Cardenas, vice president of marketing for the Car Electronics Division of Pioneer Electronics (USA) Inc.
The 4-channel GM-D8604 amplifier complements the mono amp models by providing ample power for speakers that reproduce a wider frequency range. The 4-channel model can produce up to 100 Watts x 4 (4-ohm) RMS power, 150 Watts x 4 (2-ohm) of RMS power, or 300 Watts x 2 (4-ohm bridged) RMS power when configured to play in 2-channel mode. The 4-channel model features speaker level inputs and a built-in low pass or high pass crossover with a frequency slope of 40-500Hz, making it easy to add on to any system.
All three amplifiers utilize a very small, compact chassis that is ideal for applications with limited space. Each unit has been cosmetically redesigned with a new, more durable industrial design that utilizes perforated aluminum die-cast heat sinks to provide maximum heat dissipation.
Price and Availability (November 2012)
Pioneer GM-D8604 (100-watt x 4 @ 4 ohm) $220
Pioneer GM-D9601 (500-watt x 1 @ 4 ohm) $280
Pioneer GM-D8601 (300-watt x 1 @ 4 ohm) $200
Specifications
GM-D9601 GM-D8604 GM-D8601
Number of Channels Mono 4/3/2 Mono
Maximum Power Output 2,400 W 1,200 W 1,500 W
Continuous Power Output (1 Ω, ≤ 1% THD+N) 1,200 W x 1 125 W x 4 800 W x 1
Continuous Power Output (2 Ω, ≤ 1% THD+N) 800 W x 1 150 W x 4 500 W x 1
Continuous Power Output (4 Ω, ≤ 1% THD+N) 500 W x 1 100 W x 4 300 W x 1
Continuous Power Output Bridged (4 Ω) 300 W x 2
Frequency Response 10 Hz to 240 Hz 10 Hz to 35 kHz 10 Hz to 240 Hz
Total Harmonic Distortion (4 Ω) < 0.5% (100 Hz) < 0.05% (1 kHz) < 0.5% (100 Hz)
Signal-to-Noise Ratio (IHF-A Weighted, at 1 kHz) > 100 dB > 95 dB > 100 dB
Dimensions (WxHxD) 12-3/8″ x 2-3/8″ x 7-7/8″ 10-3/8″ x 2-3/8″ x 7-7/8″ 10-3/8″ x 2-3/8″ x 7-7/8″
ATC SCM20ASL Active Bookshelf Speaker in High Gloss Cherry Finish
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Sony 2025 BRAVIA family of products Sony 2025 BRAVIA family of products
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Our favorite A/V receivers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Select Onkyo, Integra and Pioneer A/V receivers add support for Dirac Live Bass Control, Amazon Music HD, TIDAL MAX, Source-based Tone Mapping and Google...
Daily Deals
Our favorite turntables on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Priced under $500, Pioneer's refreshed entry-level 5.2-channel and 7.2 channel A/V Receivers add support for 4K/120 and 8K resolution.
Auro 3D, Auro Scene and Auro CX enable spatial audio through A/V receivers, smart speakers and music streaming.
HDTV 4K & 8K TV
Pioneer-branded TVs are back, but not in the way you think. Find out how Xumo and Best Buy are involved.
Pioneer Elite is back and this A/V receiver packs in everything that you need for your home theater setup.
Dirac Live Bass Control is coming to select Onkyo, Integra, and Pioneer Elite AVRs. The bad news is that it isn't free.
