OPPO HA-2SE Portable Headphone Amplifier and DAC Announced
OPPO HA-2SE Top View
OPPO Digital today introduced an updated version of the HA-2 portable headphone amplifier and DAC called the HA-2SE. The $300 device is engineered to enhance music playback from smartphones and portable music players. Featuring hybrid class AB amplification and a USB DAC, the HA-2SE offers high performance digital-to-analog conversion for Apple’s iPhone/iPod products, a wide range of Android devices, PC and Mac computers. Equipped with a 3000mAh internal battery and OPPO’s patented safe rapid charging technology, the HA-2SE may be conveniently used to charge mobile devices on-the-go and can itself be efficiently charged in 30 minutes.
Aesthetically, the HA-2SE continues the HA-2’s elegant style and design — genuine leather casing with contrast stitching and beveled aluminum edges. Inside, the digital-to-analog converter (DAC) chip is upgraded to the ES9028Q2M, the top-of-the-line from ESS Technology’s SABRE32 Reference series for portable designs. The headphone amplifier is further optimized for very sensitive In-Ear Monitors, with a lower noise floor and higher signal-to-noise ratio over the HA-2.
OPPO HA-2SE
Features:
  • Ultra-slim Design – Stacking the HA-2SE on top of most smartphone models is often still thinner than other portable headphone amplifier models alone.
  • ESS Sabre32 Reference DAC – ES9028Q2M DAC chip delivers high-resolution performance with extremely low noise and distortion.
  • High-Resolution Audio – The HA-2SE supports PCM audio up to 384 kHz / 32-bit, DSD audio up to 12 MHz (DSD256 or DSD4x). No Camera Connection Kit required for high-resolution playback from iOS devices.
  • Ideal Companion for iPhone 7 – The HA-2SE provides improved sound quality over the adapter that comes with the iPhone 7, and its ability to charge the phone while you listen to music resolves the issues arising from the removal of the 3.5 mm headphone jack.
  • Multiple Devices Support – The HA-2SE supports multiple device types for digital-to-analog conversion via USB: iPod / iPhone / iPad, smartphones with USB OTG feature, PC and Mac computers.
  • Mobile Power Bank with Rapid Charging – The HA-2SE functions as an external battery pack to charge mobile devices. Its internal battery can be quickly charged in about 30 minutes with the patented rapid charger.
The HA-2SE is a very mobile-centric portable headphone amplifier and DAC that pairs exceptionally well with iOS and Android devices. It works especially well with Apple’s newly released iPhone 7 and iPhone 7 Plus. Being a “Made for iPhone” certified device and coming with a Lightning cable included, the HA-2SE can charge the iPhone and play music at the same time. Its high-end DAC and high output amplifier can provide a significant improvement in sound quality and drive a much wider variety of headphones than the Lightning-to-3.5mm adapter that comes with the new iPhone. When used with the right apps, the HA-2SE supports bit-perfect playback of high resolution music, exceeding the 48 kHz sample rate limitation of using the phone’s built-in headphone output or headphone adapter.
In addition to the USB DAC inputs, the HA-2SE provides a 3.5 mm line-in jack for portable music players that do not have a USB-compatible digital output. The same jack doubles as line-out when the HA-2SE is used as a DAC. The headphone amplifier has two gain level settings. The High Gain mode is capable of driving large power-hungry headphones, delivering up to 300 mW into 16-Ohm headphones. The Low Gain mode is intended for sensitive In-Ear Monitor type earphones. For users who like a bit more punch and impact with their music, the HA-2SE offers a Bass Boost function that is implemented purely with analog audio circuits.
Price and Availability
The OPPO HA-2SE is available now for $299.
Vincent Audio SV-500 MK Hybrid Integrated Amplifier
SV-500 MK Adds HDMI ARC and Bluetooth 5.0 Connectivity and outputs 50 watts per channel for $1,500.
Fell Audio Amp and Disc Fell Audio Amp and Disc
Fell Audio aims to attract British hi-fi buyers seeking retro aesthetics with value driven audio performance from its inaugural £1000 stack.
Schiit Audio Wotan Stereo Power Amplifier Front Angle Silver Schiit Audio Wotan Stereo Power Amplifier Front Angle Silver
Lots of power, practical integration and control, and a reasonable price tag make the Wotan power amp worth consideration, especially if you own other...
Fezz Audio Equinox Vacuum Tube DAC in Sunlight Finish Front View Angle Fezz Audio Equinox Vacuum Tube DAC in Sunlight Finish Front View Angle
Starting at $2,995, the Fezz Audio Equinox Vacuum Tube DAC is the most affordable D/A converter with Lampizator technology.
iFi GO link Max Dongle DAC connected to laptop and IEM iFi GO link Max Dongle DAC connected to laptop and IEM
Dongle DACs
With more power and balanced connectivity, the iFI GO link Max dongle dac is a great upgrade over the previous GO link and only...
Audio CU Sound Over Power Audio CU Sound Over Power
A/V Furniture & Accessories
AUDIO Cu plug-in adapters eliminate long cable runs by sending up to 10 channels of audio over power lines already in your home.
dts-holiday-guide
Treat the audio enthusiast in your life to the best DTS-powered products this holiday season.
