Onkyo Introduces Budget A/V Receivers for 2016
Onkyo TX-NR555 A/V receiver with RC-911R remote
Onkyo today unveiled four new budget friendly A/V receivers priced from $400 to $800. The new lineup from lowest priced to highest includes models TX-SR353, TX-NR555, TX-NR656 and the THX Select2 Plus certified TX-NR757. The last three receivers bring high-current Dynamic Audio Amplification and state-of-the-art features to the mid-range with Dolby Atmos decoding and are DTS:X-ready. They also support 4K UltraHD video and 4K upscaling; AirPlay, and Wi-Fi, with Google Cast, Tidal music streaming and the new FireConnect multi-room audio technology soon to come via firmware update (summer 2016).
FireConnect Powered by Blackfire is a stable wireless protocol that sends any audio source connected to the receiver — from vinyl to streaming audio — to an optional Onkyo speaker or another FireConnect-compatible product in another room.
Also debuting in these three receivers is Onkyo’s AccuReflex, part of the company’s AccuEQ calibration suite. The technology adjusts the phase of sound bounced off the ceiling by up-firing speakers so that it syncs perfectly with sound from the other speakers to create a more accurate Dolby Atmos experience. Together with AccuEQ to eliminate standing waves, surround-sound is precisely balanced for supreme clarity.
Onkyo TX-NR757
TX-NR757 THX SELECT2 PLUS AV RECEIVER
The TX-NR757 7.2-Channel Network A/V Receiver features THX Theater Reference Sound, 180W of high-current power and patented VLSC high-frequency pulse-noise removal technology for crystal clear sound. Processing for lossless and Hi-Res Audio is handled by a state-of-the-art AKM 384 kHz/32-bit D/A convertor. Easily bring audio to another room with multi-zone support including multiple speaker connections for Zone 2 (2A/2B).
The TX-NR757 looks to the future with HDCP 2.2-compliant HDMI inputs supporting 60Hz UltraHD and Full HD video with 4:4:4 color space and High Dynamic Range (HDR). The receiver was also designed with custom integration in mind with RS232, 12v trigger, IR input and more on board.
Onkyo TX-N656
Onkyo TX-NR555
TX-NR656 & TX-NR555 NETWORK AV RECEIVERS
The 7.2-Channel TX-NR656 packs 170W/Ch while the 7.2-Channel TX-NR555 boasts 140W/Ch for powerful home theater experiences. Both receivers let music lovers take advantage of the full-scale stereo power through Google Cast, AirPlay, Wi-Fi, and Bluetooth streaming music from mobiles and PCs, while Onkyo’s own remote app streams everything from MP3s to hi-res audio stored on a media server. Digital music benefits from noise-free 32-bit D/A conversion with VLSC, while discrete non-phase-shift amps provide a sense of clarity and depth.
Both receivers also feature powered Zone 2 speaker terminals and support the latest in UltraHD entertainment with HDCP 2.2-compatible HDMI terminals passing 4K/60 Hz/4:4:4/HDR video through to the latest TVs for display. The TX-NR555 has 6 HDMI inputs and 1 output, while the TX-NR656 features 8 in and 2 out.
Onkyo TX-SR353
TX-SR353 AV RECEIVER
The powerful yet affordable TX-SR353 5.1-Channel A/V Receiver is engineered front-to-back to streamline and enhance daily entertainment. It features full support for 4K video (4K/60 Hz/HDR/4:4:4/HDCP 2.2) via four HDMI inputs, decoding for Dolby TrueHD and DTS-HD Master Audio common to Blu-ray discs, and video up-conversion via HDMI to reduce TV connections to a single cable.
A redesigned and clearly labeled rear panel and simple remote controller make initial setup and daily operation easy, while AccuEQ room acoustic correction ensures clear stereo imaging and equalized surround-sound. Once connected, the TX-SR353 acts as a hub for all your AV sources, from the latest 4K media players and game consoles to legacy DVD decks and VCRs, and adds 140W of dynamic audio power from five discrete analog amplifiers.
Music lovers will appreciate Bluetooth technology for wireless audio from most mobile apps, with Advanced Music Optimizer restoring lost bit information to compressed music. A USB input handles MP3s, while analog/digital terminals are available on the back panel to connect other audio players.
Onkyo TX-SR353 Rear
Onkyo TX-SR353 Rear
Onkyo TX-NR555 Rear
Onkyo TX-NR555 Rear
Onkyo TX-NR656 Rear
Onkyo TX-NR656 Rear
Onkyo TX-NR757 Rear
Onkyo TX-NR757 Rear
Price and Availability
  • Onkyo TX-SR353 $399 (mid-April)
  • Onkyo TX-NR555 $599 (mid-April)
  • Onkyo TX-NR656 $699 (mid-April)
  • Onkyo TX-NR757 $799 (May 2016)
Comparison & Specifications
TX-SR353 TX-NR555 TX-NR656 TX-NR757
MSRP $399 $599 $699 $799
Amplifier
# Channels 5.1 7.2 7.2 7.2
Power Watts/Ch (6 Ohms 1kHz, 1 Channel Driven, FTC) 140, 1.0% THD 140, 1.0% THD 170, 1.0% THD 180, 1.0% THD
Power Watts/Ch (8 Ohms 20-20kHz, 2 Channels Driven, FTC) 80, 0.08% THD 80, 0.08% THD 100, 0.08% THD 110, 0.08% THD
Dynamic Audio Amplification ✓ (for Clear and Realistic Sound) ✓ (for Clear and Realistic Sound) ✓ (for Clear and Realistic Sound)
H.C.P.S. (High Current Power Supply)
Non-Phase Shift Amplifier
THX Certified
Continuous 6 Ohms Rated
Certified 4 Ohms Performance
Discrete Output Stage Circuitry
3-Stage Inverted Darlington Circuitry
PUSH-PULL Design
Independent Block Construction (Amp/Preprocessor)
High-Grade Toroidal Transformer
Independent Power Supply
Bi-amp Capability For Front
Processing
Dolby Atmos
32-Bit Digital Signal Processing Engine
Dolby Decoder True HD Atmos, True HD, DD Plus Atmos, True HD, DD Plus Atmos, True HD, DD Plus
DTS:X
DTS Decoder DTS-HD Master Audio DTS:✓, DTS-HD Master Audio DTS:✓, DTS-HD Master Audio DTS:✓, DTS-HD Master Audio
ONKYO GAME Surround Modes ✓ (Rock, Sports, Action, RPG) ✓ (Rock, Sports, Action, RPG) ✓ (Rock, Sports, Action, RPG) ✓ (Rock, Sports, Action, RPG)
VLSC for Noiseless Audio Processing ✓ Fronts
THX Processing Mode
CinemaFILTER
AccuEQ Room Calibration ✓ w/ AccuReflex
Phase-Matching Bass Boost
Direct/Pure Mode – / – Yes/No Yes/No Yes/No
Pure Direct Analog Path Mode
384K/32 Bit DACs
192K/24 Bit DACs
Connectivity
Analog Audio IN 3 6 8 8
Phono Input
Digital Audio IN (OPT/COAX) 1 / 1 2 / 1 2 / 1 2 / 1
Composite Video I/O 2 / 1 2 / 0 2 / 0 2 / 0
Component Video I/O 2 / 0 2 / 0 2 / 0
Front Panel HDMI
Front-Panel A/V 1 (Analog) 1 (Analog) 1 (Analog)
USB Input ✓ (Front) ✓ (Rear) ✓ (Rear) ✓ (Rear)
HDMI I/O 4 / 1 6 / 1 8 / 2 (main/sub) 8 / 2 (main/sub)
HDMI 4K/60 Hz- Capable HDMI Terminals
HDCP 2.2 Copy-Protection Compatibility
HDMI Support for High Dynamic Range
HDMI Support for 3D, Audio Return Channel and CEC
HDMI Support for Deep Color, x.v.Color, LipSync
HDMI Support for DVD-Audio, SACD, Multichannel PCM
Analog To HDMI Upconversion
1080p Upscaling
4K (up to 4096 x 2160) Upscaling
4K Passthrough
Analog Pre-Outs Subwoofer Subwoofer (x2) Subwoofer (x2) Subwoofer (x2)
Speaker A/+B
Powered Zone 2 ✓ and Zone 2 A/B
Powered Zone 3
Zone 2 Line Out ✓ (Line/Pre) ✓ (Line) ✓ (Pre/Line)
Zone 2 Video Out
Zone 2 Digital to Analog Audio Conversion ✓ (Net) ✓ (Net/SPDIF) ✓ (Net/SPDIF)
Zone 3 Line Out
Whole House Mode
Made for iPod, iPhone, iPad
Airplay
Google Cast
Supports Onkyo Remote App
Internet Radio Capable
Spotify Connect Support
Tidal
Streaming Audio From PC / Network
Hi-Res Streaming Audio Formats
Streaming Audio From USB memory
Wireless Network
Bluetooth ✓ (Built-in) ✓ (Built-in) ✓ (Built-in) ✓ (Built-in)
Integration Access
RS-232
IR Input
IR Output
Ethernet
ONKYO-RI System Control
RIHD (Remote Interactive Over HDMI)
12V Trigger
Miscellaneous
Pre-Programmed Remote
Hybrid Standby Function
Smart Grid-Ready
Auto Speaker Calibration W/Mic. AccuEQ AccuEQ AccuEQ w/ AccuReflex AccuEQ
OSD Out
Solid Aluminum Front
Transparent High-Grade Speaker Terminals
Detachable AC Cord
Warranty 2 YEARS 2 YEARS 2 YEARS 2 YEARS
Remote Controls
Onkyo RC-928R Remote for TX-SR353 Onkyo RC-911R Remote for TX-NR receivers
Left: Onkyo RC-928R Remote for TX-SR353 only
Right: Onkyo RC-911R Remote for TX-NR receivers
LG G5 OLED TV Lifestyle
HDTV 4K & 8K TV
Will LG's new quad stack Primary RGB Tandem OLED panel make the G5 the best TV of 2025? And what should we expect from...
HOUCHMAND M1 System Lifestyle Image HOUCHMAND M1 System Lifestyle Image
The Houchmand M1 is an ultra high-end all-in-one two-channel digital music system with optional subwoofer for a sky high price.
Hisense 2025 ULED TV line-up Hisense 2025 ULED TV line-up
HDTV 4K & 8K TV
Brighter, bigger, and more powerful, the Hisense 2025 ULED TV lineup should have something for everyone.
Pro-Ject Automat A1.2 Turntable Lifestyle Pro-Ject Automat A1.2 Turntable Lifestyle
Updated with a new die-cast aluminium platter, Pick It MM E phono cartridge and other refinements, the Automat 1.2 might be the most logical...
NAGRA Compact Phono Stage Angle NAGRA Compact Phono Stage Angle
At $4,950, the Nagra Compact Phono is a "lower cost" high-end audio solution for getting the most out of your vinyl record listening experience.
JADIS JS2 SL DAC Front Angle Top Open JADIS JS2 SL DAC Front Angle Top Open
Do you really need a DAC that costs between $14,000 and $18,000? Bluebird Music thinks the Jadis Vacuum Tube JS5 or JS2 SL are...
Experience the full impact of Super Bowl LIX in your living room with both a big picture and big sound.
Mixed in with the robots, electric cars, AI solutions, VR headsets and smart glasses, we found these exciting and innovative audio/video products that hit...
With more options than we've seen in years, here are our picks for Editors' Choice Awards for AV receivers in 2024.
Our favorite A/V receivers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
The backbone of a home theater or surround sound system, today's best AVRs are packed with features and performance (updated for 2024)
Klipsch, Onkyo and Integra have been swept up in Gentex's acquisition of VOXX International. Can they all survive in 2025?
Select Onkyo, Integra and Pioneer A/V receivers add support for Dirac Live Bass Control, Amazon Music HD, TIDAL MAX, Source-based Tone Mapping and Google...
Denon's budget friendly Dolby Atmos AV receiver offers excellent connectivity and sound quality for under $600.
