Monitors
NEC CRV43 Ultra-Wide Curved 43-inch LCD Monitor
Image converted using ifftoany
Designed for Simulation, Digital Imaging, Command & Control Applications
NEC Display Solutions of America, a leading stand-alone provider of commercial LCD displays and projectors, today announced the 43-inch NEC CRV43 ultra-widescreen specialty desktop display, designed for use in applications such as professional graphics, higher education, government, financial, command & control and home office.
The unique NEC CRV43 curved display provides a much wider field of view and greater dynamic range with its double WGXA resolution (32:10 aspect ratio). The user’s taskbar is extended natively and setup is made easy to configure with one input. These features make it an ideal solution for simulation, digital imaging and command & control.
“The NEC CRV43 curved display provides an excitingly immersive viewing experience for any type of user,” said Keith Yanke, Director of Product Marketing for NEC Display Solutions. “Its lightning-fast response time coupled with its seamless curved screen provides enhanced comfort, decreased frustration and increased productivity. The monitor eliminates the bezel and screen gap issues that have complicated users’ work environments for years.”
The NEC CRV43 curved display includes the following features:
  • Seamless curved screen, which eliminates bezel and screen gap issues for increased productivity and decreased frustration (according to Center for Human-Computer Interaction — Shupp et al., presented at Graphics Interface 2006)
  • 2880 x 900 double WXGA native resolution
  • 200 cd/m2 brightness
  • 0.02ms Rapid Response
  • 10,000:1 contrast ratio
  • Wide color gamut with 100% coverage of sRGB and 99.3% coverage of Adobe RGB
  • Single link DVI-D and HDMI 1.3 input connectors
  • USB 2.0 connectivity for easy use of peripherals
  • Front panel controls
  • On Screen Display (OSD) and software-based GUI, which enable advanced display control options
NEC CRV43
The NEC CRV43 curved display is backed by a 3-year parts and labor warranty including the backlight and will be available for July 2009 shipment with estimated street price of $7,999.
About NEC Display Solutions of America, Inc.
Headquartered in Itasca, Ill., NEC Display Solutions of America, Inc., is a leading designer and provider of innovative desktop LCD displays, professional-grade large-screen LCD displays, a diverse line of projectors, and integrated display solutions. NEC Display Solutions develops leading-edge visual technology and customer-focused solutions for a wide variety of markets, including enterprise, professional, education, medical and digital signage.
EE1 Plus with Cable
Audio Cables
At £600, the EE1 Plus is designed to reduce interference and noise on wired networks, but do you really need it?
Michell Audio Apollo Phono Preamplifier and Muse Power Supply Michell Audio Apollo Phono Preamplifier and Muse Power Supply
Does the Michell Audio range of high-end turntables finally have a complementary phono pre-amplifier to match its capabilities? The Michell Apollo looks ready to...
Optoma Photon Go UST Projector Black Optoma Photon Go UST Projector Black
With an RGB triple laser light source, Google TV, built-in battery, and low price, the Photon Go might be a great home entertainment option.
Shanling EH2 Headphone Amplifier and DAC Shanling EH2 Headphone Amplifier and DAC
Forte Distribution previews Shanling's $399 EH2 DAC Headphone Amp for CanJam Attendees
FiiO FT7 Open-back Planar Magnetic Headphones Angle FiiO FT7 Open-back Planar Magnetic Headphones Angle
The FiiO FT7 Open-back Planar Magnetic Headphones will debut at the Bristol Hi-Fi Show and CanJam NYC this weekend.
WiiM Vibelink Amp Lifestyle WiiM Vibelink Amp Lifestyle
WiiM is well-known for its streaming products, but they are expanding their reach with a dedicated integrated amplifier.
Ultimate Man Cave Gift Guide 2025
Unwind in the ultimate man cave and escape into home entertainment bliss with incredible gift ideas for hi-fi audio or home theater.
