CD Players
Marantz SA8005 Super Audio CD Player / DAC
Marantz SA8005 SACD Player
Marantz today introduced the audiophile-grade SA8005 super-audio compact-disc (SACD) player, which features faster, low-noise and lower impedance symmetrical circuits with high-quality components, over the SA8004 SACD player. The loading mechanism virtually eliminates resonance, while its reduced distortion spectrum gets the very best audio quality from SACDs.
Besides being a top-class SACD player, the SA8005 also functions as a standalone digital-to-analog convertor (DAC), using the Cirrus Logic CS4398 chip. The unit has optical and coaxial digital input for various digital sources, a USB-A input on the front panel for popular portable devices, as well as an asynchronous USB-B input for direct connection to a PC. The asynchronous USB-B input supports decoding and playback of high resolution audio DSD 2.8MHz and 5.6MHz formats and features a newly developed ground/signal isolator technology which virtually eliminates PC noise.
The rugged chassis features a dual layer bottom plate for high rigidity and freedom from vibration-induced distortion, and the center mounted disc drive features its own isolated sub-chassis that provides further vibration protection. The front panel USB-A port lets you connect your favorite portable audio device, and is compatible with iPod, iPod touch and iPhone sources. The rear panel USB-B port lets you connect your home PC to play back digital audio files, including high resolution PCM and DSD tracks.
Marantz SA8005 SACD Player Back
The SA8005 also features an accurate dual-system clock, a Toroidal transformer, a double-layered bottom plate for extra stability, fully discrete headphone amplifier, and a system remote, which controls the SA8005 and the matching PM8005 amplifier.
Price and Availability
The Marantz SA8005 Super Audio CD Player with USB-DAC will be available for $1,199.
Placing record on Turntable PP-1 from above
Are you one of those people who hates having to install a phono cartridge? The Waiting for Ideas PP-1 might be exactly what you're...
EE1 Plus with Cable EE1 Plus with Cable
Audio Cables
At £600, the EE1 Plus is designed to reduce interference and noise on wired networks, but do you really need it?
Michell Audio Apollo Phono Preamplifier and Muse Power Supply Michell Audio Apollo Phono Preamplifier and Muse Power Supply
Does the Michell Audio range of high-end turntables finally have a complementary phono pre-amplifier to match its capabilities? The Michell Apollo looks ready to...
Optoma Photon Go UST Projector Black Optoma Photon Go UST Projector Black
With an RGB triple laser light source, Google TV, built-in battery, and low price, the Photon Go might be a great home entertainment option.
Shanling EH2 Headphone Amplifier and DAC Shanling EH2 Headphone Amplifier and DAC
Forte Distribution previews Shanling's $399 EH2 DAC Headphone Amp for CanJam Attendees
FiiO FT7 Open-back Planar Magnetic Headphones Angle FiiO FT7 Open-back Planar Magnetic Headphones Angle
The FiiO FT7 Open-back Planar Magnetic Headphones will debut at the Bristol Hi-Fi Show and CanJam NYC this weekend.
Ultimate Man Cave Gift Guide 2025
Unwind in the ultimate man cave and escape into home entertainment bliss with incredible gift ideas for hi-fi audio or home theater.
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
The Best CD Players for 2023 include some fantastic units from NAD, Naim, Rotel, Marantz, Audiolab, Cambridge Audio and more.
At $12,000, the Marantz Link 10n is the company's flagship network audio player designed to be paired with Model 10 Integrated Amplifier.
CD Players
At $12,000, the new Marantz SACD 10 is the best CD/SACD player the company has ever made and it weighs 73 lbs.
At $1,500, the Marantz 60n is a 60-watt per channel integrated amp that connects to a TV, CD Player, turntable, and streams music.
In this episode the eCoustics teams reveals its Best in Show product awards from CEDIA Expo 2024 across 17 different categories.
Part 3 of 3 from CEDIA Expo 2024 highlights Ascendo, Theory Audio, Bowers & Wilkins, L-Acoustics, TCL, JVC and Grimani Systems.
Developed over five years at the renowned Shirakawa Audio Works in Japan, the Marantz Model 10 Reference Integrated Amplifier embodies unparalleled heritage, performance and...
