HiFiMAN HE400S Planar Magnetic Headphones
HiFiMAN HE400S Headphones
HiFiMAN today released their most affordable full-size planar-magnetic headphone, model HE-400S for $299, which currently is the least expensive planar headphone on the market. Weighing in at just over 12 ounces (350 grams), the HiFiMAN HE-400S is more than 30% lighter than comparable headphones allowing the listener to comfortably enjoy music for hours on end with minimal listener fatigue. A newly-designed ergonomic headband, found in more expensive models, is lighter with an improved pressure pattern that is also key to the phone’s exceptional comfort. The headband is designed to accommodate a wide range of head sizes. The new beveled velour ear pads provide both increased comfort and improved sound quality while the silver ear cups offer a stylish, high-tech look.
On the technical front, the HE-400S challenges the status quo with newly-designed single-ended planar magnetic drivers in open-back design that deliver the clarity, lifelike soundstage and spatial imaging that HiFiMAN is known for. Sensitivity is increased to 98dB, which allows the efficient HiFiMAN headphone to be driven easily with a portable audio device such as an iPod or smartphone though ultimate performance would only be achieved if paired with a quality amplifier. Impedance of the HE400S is 22 Ohms.
HiFiMAN HE400S Headphones Folded
To capture every bit of sonic detail, a newly-designed hybrid cable, comprised of Oxygen-Free Silver and Copper was chosen for HE400S. Also new from HiFiMAN are 2.5mm plug-in connectors for ease of use and quick connection as well as ease of replacement.
Features
  • Planar magnetic technology provides remarkable detail and lifelike clarity with superior soundstage and spatial imaging
  • Increased efficiency so it is even easier to drive. Can be used with portable audio devices such as an iPod or smartphone or high performance amp
  • Ergonomic headband provides optimum comfort and wide range of adjustment
  • Lightest weight in class for increased comfort for hours of listening enjoyment.
  • Beveled velour ear pads provide increased comfort and improved sound
  • Newly-designed cable with easy plug-in connectors
Price and Availability
The HiFiMAN HE400S headphones are available now for $299. Now $149 at Amazon.
Related reading: HiFiMAN HE400se Headphones Review
1 Comment
1 Comment
  1. Matamoscas
    July 9, 2015 at 8:45 pm
    In terms of sound quality is the HE400S on the same level as HE400i? Now with this new headphones i’m very undecided to buy the 400i… I dont want spend 200$ more for the same headphones
Hisense 2025 ULED TV line-up
HDTV 4K & 8K TV
Brighter, bigger, and more powerful, the Hisense 2025 ULED TV lineup should have something for everyone.
Pro-Ject Automat A1.2 Turntable Lifestyle Pro-Ject Automat A1.2 Turntable Lifestyle
Updated with a new die-cast aluminium platter, Pick It MM E phono cartridge and other refinements, the Automat 1.2 might be the most logical...
NAGRA Compact Phono Stage Angle NAGRA Compact Phono Stage Angle
At $4,950, the Nagra Compact Phono is a "lower cost" high-end audio solution for getting the most out of your vinyl record listening experience.
JADIS JS2 SL DAC Front Angle Top Open JADIS JS2 SL DAC Front Angle Top Open
Do you really need a DAC that costs between $14,000 and $18,000? Bluebird Music thinks the Jadis Vacuum Tube JS5 or JS2 SL are...
Samsung Neo QLED TV 2025 with Vision AI Samsung Neo QLED TV 2025 with Vision AI
HDTV 4K & 8K TV
Samsung just unveiled pricing and availability details for its full line of Neo QLED TVs in both 4K and 8K resolution. Potential buyers may...
Samsung HW-Q990D. Samsung HW-Q990D.
The first soundbar with Eclipsa Audio decoding, Samsung's new flagship Q990F may be the one to beat in 2025.
Apple is adding Lossless Audio and Ultra-Low Latency to the AirPods Max Headphones, but only when wired.
The traveling headphone show, CanJam came to New York City last month and we were there. Here are a few highlights.
Over-Ear Headphones
HiFiMAN Arya Unveiled open-back headphones feature exposed planar magnetic drivers and an all-new sound. Find out how it compares to the prior Organic and...
Focal extends its wired headphone range with two affordable models based on the Bathys architecture in open and closed-back configurations.
At $1,400, the fourth-generation Arya Unveiled features a removable “Magnetic Veil” back panel and Stealth Magnet Technology.
Headphones
The 10th Guangzhou International Headphones Expo was successfully held on the 14th and 15th of December 2024.
Check out our favorite wired over-ear headphones at different price points, from very affordable to cost no-object.
Our picks for the best wireless noise cancelling headphones to buy in 2022 at various price points may surprise you.
