Digital Foci Announces Memory Card Travel Case
For photos:
http://www.thomas-pr.com/136/photos/digitalfocitravelcase.html
http://www.thomas-pr.com/136/photos/digitalfocitravelcaseopen.html
http://www.thomas-pr.com/136/photos/digitalfocitravelcaseopenedflat.html
http://www.thomas-pr.com/136/photos/digitalfocitravelcasepackaging.html
For product information: http://www.digitalfoci.com/memory_card_travel_case.html
For release: http://www.thomas-pr.com/pressreleases/digitalfocimemorycard.html
Contact:
Karen Thomas
Thomas PR
(631) 549-7575
kthomas@thomas-pr.com
DIGITAL FOCI ANNOUNCES MEMORY CARD TRAVEL CASE
Holds All Types of Memory Cards
Unique Smart Stackable Design Organizes up to 8 Memory Cards of Any Type
Los Angeles, California, March 15, 2006 — Digital Foci, Inc. (www.digitalfoci.com), a leading provider of digital photo albums, digital frames and accessories, introduced today the Memory Card Travel Case, which organizes and protects all important digital flash memory cards in one place. The Digital Foci Memory Card Travel Case is the only case you will ever need on vacation or for business travel to protect your important cards. Elegant as well as durable, the case features a sturdy silver brushed aluminum shell with hard rubberdized lining providing maximum protection and accessibility for those tiny easy-to-lose memory cards.
Memory cards are now used in almost every electronic product today, including digital and video cameras, MP3 Players, PDAs, and even cellphones. Since each device uses a different type of card, you need to have a travel case that will fit multiple cards formats. The Digital Foci Memory Card Travel Case fits all types of memory cards: CompactFlash I/II, MD, SM, MMC, SD, miniSD, MS, MS PRO, MS Duo, and xD card. Its unique multi-format design allows travelers to stack up to 8 different memory cards. The case’s molded hard rubber lining protects these memory cards by keeping them snugly in place.
Digital Foci Memory Card Travel Case Features:
• Smart stackable slots let you hold as many as 8 memory cards
• Holds all different memory card types
• Molded hard rubber lining
• Sturdy brushed aluminum shell
Priced at $19.95, the Digital Foci Memory Card Travel Case is available immediately online at: www.digitalfoci.com.
DIGITAL FOCI MEMORY CARD TRAVEL CASE SPECS
Model no. MTC-810
Memory card supported CompactFlash I & II
MicroDrive
SmartMedia
MultiMedia Card
SD Card
miniSD*
Memory Stick
MS PRO
MS Duo*
MS PRO Duo
MagicGate MS
xD Picture Card
* fit into slot with adapter
Dimensions 4.2″ (L) x 2.8″ (W) x 0.7″ (H)
Weight 3.5 oz.
