Bronze Member Username: EcousticsPost Number: 17 Registered: 12-2003 | This review has moved to the location below: https://www.ecoustics.com/reviews/sherbourn-pt-7000-preamplifier-72100-amplifier/ |
New member Username: A016691Post Number: 3 Registered: 01-2004 | Did you happen to purchase this equipment or was it a Gift (Sorry, I mean loaner) to get the publicity?? If you did buy it did you have to pay the full price?? |
Bronze Member Username: EcousticsPost Number: 18 Registered: 12-2003 | Both products were loaned directly from Sherbourn. |
Unregistered guest | "Did you happen to purchase this equipment or was it a Gift (Sorry, I mean loaner) to get the publicity?" No offense but that comment was rather rude David. |
Pam Unregistered guest | Agreed what was the point of it? |
B0B Unregistered guest | Can someone tell me if the Sherbourn, Outlaw and Atlantic Technology processors are all one in the same? They look very similar and appear to have the same feature sets. Thanks. |
Diamond Member Username: EcousticsFairfax, VA USA Post Number: 172 Registered: Dec-03 | This article from Audioholics.com explains the similar processors. |
Unregistered guest | Hi, i'm considering to buy the sherbourn amp. and preamp. but i also read good reviews from rotel. wich would you advise? Thanks |
